Leader that displays attribute
rbh1
Message 1 of 11
rbh1
Is anyone aware of how to make a leader that will read attributes from a block?  I would like to create a leader that will read the attributes from a block and place them in a bubble (circle) leader.
Thank you for ay assistance you may be able to provide.
Replies (10)
Message 2 of 11
devitg
@rbh1 For better understanding, and maybe get further help, please upload such sample.dwg
Message 3 of 11
pbejse
That means more than one attribute in a block? and concatenate them in one attribue in the leader?  perhaps use Multileader instead, one that use "_TagCircle" attribute block. Do you need it as Field value ?
Message 4 of 11
rbh1
Here is an example of what I would like to do.
I would like for the leader to prompt for the block and fill in the attributes.
I have created my blocks with the same attribute names to keep it simple and standard.
There two different examples.  the F/N 06 is what I am trying to accomplish.  the other one is another leader I would like to do once I learn how to do accomplish the first one.
Thank you all for any help you can give.
Sincerly
Message 5 of 11
pbejse
You realize the Multileaders have two different ContentType.
Here's one for the "MText/Contents"
(defun c:demo (/ ss source sourceID)
  (if (and
	(princ "\nSelect Callout")
	(setq ss (ssget "_+.:S:E:L" '((0 . "MULTILEADER"))))
	(princ "\nSelect Source")
	(setq source (ssget "_+.:S:E" '((0 . "INSERT") (66 . 1))))
      ) ;_ end of and
    (progn
      (if
	(vl-some '(lambda (at)
		    (if	(eq (vla-get-tagstring at) "FINDNUMBER")
		      (setq sourceID (itoa (vla-get-objectid at)))
		    ) ;_ end of if
		  ) ;_ end of lambda
		 (vlax-invoke
		   (vlax-ename->vla-object (ssname source 0))
		   'GetAttributes
		 ) ;_ end of vlax-invoke
	) ;_ end of vl-some
	   (setpropertyvalue
	     (ssname ss 0)
	     "MText/Contents"
	     (strcat "F/N "
		     "%<\\AcObjProp Object(%<\\_ObjId "
		     sourceID
		     ">%).TextString>%"
	     ) ;_ end of strcat
	   ) ;_ end of setpropertyvalue
      ) ;_ end of if
    ) ;_ end of progn
  ) ;_ end of if
  (princ)
) ;_ end of defun
Let see how you fair with the other type
** Requries a regen **
Message 6 of 11
rbh1
Thank you very much.  I will try this out.
Message 7 of 11
Sea-Haven
Hi PBE maybe a suggestion rather than hard coding the tag name as you can not see a attribute use the attribute order to get tag name, so dbl click block and look the "FINDNUMBER" would be attribute 2 remember that. So when running would enter tag order 2, this way becomes a bit more global working for any block. Typing a number is a bit quicker than a tagname.
Perhaps a Enter tagname or order.
Message 8 of 11
pbejse
@Sea-Haven wrote:
... this way becomes a bit more global working for any block. Typing a number is a bit quicker than a tagname.
I like the idea of making the code more generic  👍 We might as well do that with this one..
(defun c:demo (/ _init ss source sourceID)
(defun _init (l)
  ( (lambda (init choice)
      (foreach str l
        (setq init (Strcat init (car str) " ")
              choice  (Strcat  choice (car str) " " (Cadr str) "/")))
      		(list init choice 2)
  (if (and
    (progn
      ( (lambda (i)
      (setq attVal (mapcar '(lambda	(att)
			  (list	(itoa (setq i (1+ i)))
				(strcat (vla-get-tagstring att))
				(itoa (vla-get-objectid att))
		       (vlax-invoke
			 'GetAttributes
	  0)
      	(setq choices (_INIT  attVal))
	(initget 1 (Car choices))
	(setq option (getkword (strcat "\nChoose option [" (Cadr choices) "]: ")))
        (setq sourceID (caddr (nth (1- (atoi option)) attVal)))
	   (setpropertyvalue
	     (ssname ss 0)
	     "MText/Contents"
	     (strcat "F/N "
		     sourceID
		     ">%).TextString>%"
  (princ)
Either you click on the choice of type in a number
It this particular demo code
Command: DEMO
Select Callout
Select objects:
Choose option [1 PARTNUMBER/2 FINDNUMBER/3 DESCRIPTION/]:
HTH
Message 9 of 11
Sea-Haven
Nice solution
Message 10 of 11
pbejse
@Sea-Haven wrote:
Nice solution
Glad you like  👍 it, I was hoping the OP would get back to us with what the info for the other Mleader type. It would've been fun to code.
Message 11 of 11
rbh1
I apologize I have been working on another project but back on it now.  I will let you know about the other leader and try out your solution.  Thank you very much for taking out the time to provide the code for me to try.
