Error with SSADD
Error with SSADD
mschirmer
Error with SSADD
mschirmer
I have a door command we have used since around 1997 and it has only been updated a few times to solve issues as they come up.   We have moved from 2016 from 2014, due to some educational stamp issue that invaded our drawings templates.  Since i test the cad versions before implementing, i never discovered any issues with a few of our lisp routines, like the door command.  Since i haven't had the issue, i waited til i had a file the issue was occuring in to find out what was the issue.  I'm not sure this is the only issue, but when i type in (setq ssn (ssadd)) i get an error in this file for this statement.  The files i specifically work in do not get this error.  I apologize i don't have the error statement from the other day, but i believe it was fairly generic error.  Does this sound like a file with errors in it or something different?
paullimapa
what if you use instead of ssn (setq sstest (ssadd))
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
