Need Mirror lisp routine
sssteve72
sssteve72
Does anyone know of a lisp routine for the mirror command that works exactly like the mirror command with one exception.
When you mirror a block it doesn't just change the graphic display of the block but it actually changes the block rotation property to be 180 degrees opposite of what was mirrored?
Custom Build with Win7 Pro 64Bit SP1
Gigabyte Tecohnology Co. X79-UD3
3.60 gigahertz Intel Core i7-3820
16GB GSkill Ripjaw Z PC3 2133 PC17000
PCI-E ATI FirePro V7800 2GB 256bit
ATA SanDisk SDSSDX24 SCSI Disk Device (256 GB)
Dell 2001FP, 2407WFPHC, ASUSVN289 in Triple monitor setup
Question - Are you the Common Denominator?
Kent1Cooper
How about a 2-items-filling-the-360-degrees Polar Array, with the center of the Array being the point on what would have been the Mirror axis that's closest to the Block location?
Kent Cooper, AIA
sssteve72
That is a decent work around.  It's a few extra steps but seems to work properly after exploded.
Thanks!
Kent1Cooper
If you call for the Array to not be associative, or use the ARRAYCLASSIC command, or for anyone with an older version of AutoCAD [I don't know when Array changed to being associative by default], you won't need to Explode the result -- it will leave you with independent objects rather than an Array object.
Kent Cooper, AIA
