ERROR STARTUP LOAD
ERROR STARTUP LOAD
seabrahenrique
ERROR STARTUP LOAD
seabrahenrique
I have a lisp to load my DVB file:
(defun S::STARTUP()
(VL-VBALOAD "C:/FazProjetoCAD/Código/FazProjetoCAD.dvb")
This error is ocurring:
What it can be?
dlanorh
What version and flavour of Autocad are you using?
Does (command "_-vbaload"   "C:/FazProjetoCAD/Código/FazProjetoCAD.dvb") work on the command line?
I am not one of the robots you're looking for
seabrahenrique
I thought the same thing at the moment of your reply!
It worked! Thanks 🙂
dlanorh
Your are using a visual lisp call in your startup => (VL-VBALOAD "C:/FazProjetoCAD/Código/FazProjetoCAD.dvb")
so if it's not loaded anywhere else try putting (vl-load-com) as the first line in the startup.
(defun S:STARTUP()
(VL-LOAD-COM)
