08:02 PM
Quick 'n dirty version.
(defun c:Test (/ T_Selection T_BasePoint T_Direction T_Rotation T_NumberOfCopies T_Angle T_Distance T_StartPoint T_Object) (if (and (setq T_Selection (ssget)) (setq T_BasePoint (getpoint "\nBasepoint : ")) (setq T_Direction (getpoint T_BasePoint "\nDistance & Direction: ")) (setq T_Rotation (getreal "\nRotation : ")) (setq T_NumberOfCopies (getint "\nNumber of copies : ")) ) (progn (setq T_Angle (angle T_BasePoint T_Direction)) (setq T_Distance (distance T_BasePoint T_Direction)) (setq T_Rotation (* T_Rotation (/ pi 180))) (setq T_StartPoint T_BasePoint) (vla-StartUndoMark (vla-get-ActiveDocument (vlax-get-acad-object))) (foreach T_Object (vl-remove-if '(lambda (T_Item) (listp (cadr T_Item))) (ssnamex T_Selection)) (setq T_Object (vlax-ename->vla-object (cadr T_Object))) (repeat T_NumberOfCopies (setq T_Object (vla-Copy T_Object)) (vla-Move T_Object (vlax-3D-Point T_StartPoint) (vlax-3D-Point (setq T_StartPoint (polar T_StartPoint T_Angle T_Distance)))) (vla-Rotate T_Object (vlax-3D-Point T_StartPoint) T_Rotation) ) (setq T_StartPoint T_BasePoint) ) (vla-EndUndoMark (vla-get-ActiveDocument (vlax-get-acad-object))) ) ) (princ) )
@DannyNLwrote:Quick 'n dirty version.
That's exactly what I want!!
Thank you very much!!
