Is there a way to array with rotation?
Is there a way to array with rotation as shown in the picture above?
DannyNL
Quick 'n dirty version.
(defun c:Test (/ T_Selection T_BasePoint T_Direction T_Rotation T_NumberOfCopies T_Angle T_Distance T_StartPoint T_Object)
   (if
      (and
         (setq T_Selection      (ssget))
         (setq T_BasePoint      (getpoint             "\nBasepoint           : "))
         (setq T_Direction      (getpoint T_BasePoint "\nDistance & Direction: "))
         (setq T_Rotation       (getreal              "\nRotation            : "))
         (setq T_NumberOfCopies (getint               "\nNumber of copies    : "))
      (progn
         (setq T_Angle    (angle T_BasePoint T_Direction))
         (setq T_Distance (distance T_BasePoint T_Direction))
         (setq T_Rotation (* T_Rotation (/ pi 180)))
         (setq T_StartPoint T_BasePoint)
         (vla-StartUndoMark (vla-get-ActiveDocument (vlax-get-acad-object)))
         (foreach T_Object (vl-remove-if '(lambda (T_Item) (listp (cadr T_Item))) (ssnamex T_Selection))
            (setq T_Object (vlax-ename->vla-object (cadr T_Object)))
            (repeat T_NumberOfCopies
               (setq T_Object (vla-Copy T_Object))
               (vla-Move   T_Object (vlax-3D-Point T_StartPoint) (vlax-3D-Point (setq T_StartPoint (polar T_StartPoint T_Angle T_Distance))))
               (vla-Rotate T_Object (vlax-3D-Point T_StartPoint) T_Rotation)
         (vla-EndUndoMark (vla-get-ActiveDocument (vlax-get-acad-object)))
   (princ)
DannyNL
   (if
      (and
      (progn
   (princ)
That's exactly what I want!!
Thank you very much!!
DannyNL
You're welcome & glad I could help Smiley Happy
