Error: no function definition: VLAX-GET-ACAD-OBJECT
mcweb
Message 1 of 12
mcweb
This is ACAD 2022.
Several of my lsp routines that I use are getting this error or similar:
I first noticed it was Lee Mac's text2mtext https://lee-mac.com/text2mtext.html
But it has done this on several other lsp routines I use.
What did I do? HELP!
Replies (11)
Message 2 of 12
komondormrex
does not restarting autocad help?
Message 3 of 12
mcweb
Thanks. No unfortunately not. I have restarted the computer also (Windows10)
Message 4 of 12
pkenewell6347
You need to load the Visual LISP environment first with (vl-load-com).
Message 5 of 12
mcweb
I have read about this and must be doing something wrong. Please tell me exactly how to do this.
I tried pasting (vl-load-com) to the command line and <enter>. ACAD accepts it with no error or message. I still get the VLAX-GET-ACAD-OBJECT error when running various lsp routines. I have also tried this command in various locations inside the lsp routine itself, with no luck.
Message 6 of 12
pendean
Community Legend
Community Legend
@mcweb wrote:
This is ACAD 2022...
is this an OEM version of AutoCAD 2022?
Or do you have a major add-on installed?
Is this a sudden new problem? aka it used to work just fine?
Why do you need that LISP when core AutoCAD 2022 already has tool that built-in?
Message 7 of 12
mcweb
I did the registry solution from here:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-no-function-...
I modified the paths for my version 2022.
I saw that page before in my searching, but it wasn't the exact error message, and I didn't want to mess it up more.
Message 8 of 12
mcweb
Lee Mac's is more functional.
Message 9 of 12
pkenewell6347
(vl-load-com) should just be loaded before running any Visual LISP (vl, vla, vlax, vlr) functions. I usually put it at the top of my lisp file to run immediately when loading.
If this is not working - you may have a corrupted Install. I don't know what would cause otherwise.
Message 10 of 12
paullimapa
Try reset AutoCAD?
Paul Li
IT Specialist
@The Office
Message 11 of 12
mcweb
Now the question is, why did it happen? 🤔
Message 12 of 12
mcweb
It was happening on several other ones besides Lee Mac's.
