Lsp to turn on selected object's layer
aitorm
aitorm
Hi!
There is an operation that I keep repeating and that would love to optimize. However, I am not very good at programing with lisp so I would like to ask you for some help. I would like Autocad to turn every layer on, so I can choose a layer, then return to the previous layer settings and then turn on selected layer. How would I approach this? Probably doing something like this:
  • Turn All Layers On: It makes all layers visible using the LAYON command.
  • Select an Object: The user selects an object, and the layer name of that object is retrieved.
  • Save object's layer: The layer name of that object is saved as "target".
  • Restore Layer Settings: Restores the layer states to what they were before turning them all on using the LAYERP command.
  • Turn "target" Layer On: The selected object's layer is turned on.
  • EXTRA: If the layer is already on, then say: "Caution! Layer was already on".
Should I try to write LSP code? Ok, I did have a conversation with chatgpt and tried to guide him,  but I don't get him to do it right!
(defun c:LayerOn (/ selObj layerName)
  ;; Turn all layers ON (but do not unfreeze them)
  (command "_.LAYON")
  ;; Prompt the user to select an object
  (princ "\nSelect an object to keep its layer on: ")
  (setq selObj (entsel))
  (if selObj
    (progn
      ;; Get the layer name of the selected object
      (setq layerName (cdr (assoc 8 (entget (car selObj)))))
      ;; Restore the previous layer settings
      (command "_.LAYERP")
      ;; Turn on the selected layer if it was off
I DON'T KNOW HOW TO DO THIS
      ;; Confirm the action
      (princ (strcat "\nLayer " layerName " is now visible."))
    ;; If no object is selected
    (princ "\nNo object selected.")
  (princ)
Thanks a lot
ВeekeeCZ
Try this routine that I have used for years.
aitorm
SOOO GOOD!!
Cool that you can choose several layers.
Thanks!!!
Kent1Cooper
Another is LayerThawOnSelect.lsp, >here<.  It shows you which Layers were frozen and/or off [not just those that were off], by highlighting, and when you pick something on one of those Layers, unhighlights everything on it.
Kent Cooper, AIA
