Coordinates in DMS format
allwinaugustine
allwinaugustine
I got this lisp code from online (www.cadlispandtips.com) showing coordinates in UTM format.
Can someone edit it to show coordinates in DMS (Degrees, Minutes, Seconds) format ?
It may require a prompt to ask Zone and Hemisphere(N/S), Not sure.
Kent1Cooper
What should be the format of the information?  It must involve a distance as well as a DMS angle.  It should be simple to forget the 'enx' and 'eny' variables, and replace this line:
        (command "leader" enp1 ptl "" (strcat "E " enx) (strcat "N " eny) "")
with different text content.  But where does the distance go in relation to the angle, some symbol between them or on different lines, how many decimal places in the distance [or what denominator fraction], how many [if any] in the seconds part of the angle, etc.?
Kent Cooper, AIA
Sea-Haven
"show coordinates in DMS (Degrees, Minutes, Seconds) " are you talking about Latitude & Longitude which can be DDDMMSS or DDD.xxxxxxxx decimal.
33°51'39"S 151°12'27"E  33.8527777777778,151.275
allwinaugustine
This is the required format.
Sea-Haven
So you want lat & long ? This is not a here is answer much more complicated depends on where you are in the world with reference to the spot of the co-ordinates not where you live.
Google convert co-ords to Laitutude & Longitude.
If your using CIV3D can be done.
