Error in Code at (while (findfile) ... Error: bad argument type: stringp nil
hawarch
hawarch
Writing a Lisp program that will create a new sheet in the project file directory.  Using a "while" command to see if the sheet exist using "findfile" and if it does, then add the next available sheet number until it finds a sheet that does not exist, then create and open it.  I'm getting this error at the "(while (findfile fp) ... " point in the code.  Cannot understand why.  Can anyone help.  THanks.
(defun c:newshtx (/ shtin fnd job fin sht1 sht2 fnx fo fp)
(if (= nil fns)(setq fns "A300.00" ))
(setq hadn (getvar "dwgname")) ;current drawing name
(setq hapa (getvar "dwgprefix"));current path
(princ (strcat "\nSheet will be created into the Current Folder: " hapa " "))
(setq job (substr (getvar "dwgname") 1 7)
fnx 0
fo (strcat job " A000.99.DWG")
fp (strcat hapa job " " fns ".dwg") );s
(princ (strcat "\n " fp))
(if (= (substr fns 5 1) ".")(setq fnp (substr fns 1 2)) (setq fnp (substr fns 1 3)) );i
(while (findfile fp) (setq fp (strcat hapa job " " fnp
(setq fnn (if (<= 10 fnx) (itoa (setq fnx (1+ fnx))) (strcat "0" (itoa (setq fnx (1+ fnx)))) )) ".00.dwg") );s
(setq fn (strcat fnp fnn))
(princ (strcat "\n " fp " | " fn)) );w
(if (numberp (read (substr (getvar "dwgname") 1 4)))(progn
(setq fin (strcase (getstring (strcat "\nPress Return to Accept Next Drawing Number (" fnp "-" (substr fnn 1 5) ") or Assign New Number: "))))
(if (= fin "")(setq fn fn)(setq fn fin))
(if (findfile fp)(alert (strcat "Sheet " fn " Already Exist. \nVerify Next Available Sheet Number and Try Again."))(progn
(if (findfile fo)(progn
(vl-file-copy (findfile fo) fp)
(vla-activate (vla-open (vla-get-documents (vlax-get-acad-object)) fp)) );p
(alert (strcat "Master Sheet " fo " Not Found")) );i
))) ;pi p
(alert "File Cannot be Created - Open a Drawing File in the Project's Job Folder and Run Again") );i
Sea-Haven
You may be better getting a list of filenames Visual Lisp - Directories and Files - Page I. (afralisp.net) then use that do a sort etc and look at last.
hawarch
Thanks, I'll look into doing it that way as well. Still does not make sense as to why the (while (findfile xx)
method will not work.
paullimapa
Doesn't seem to error out for me as I step through your lines of code all the way through to your while loop with the drawing file under My Documents.
Have you tried running the code one line at a time to see if that works for you?
Paul Li
IT Specialist
@The Office
