Align blocks to multiple lines in one go.
q_Q25S5
q_Q25S5
I currently am doing some work in Autocad where i have to place a couple of 100 blocks at the endpoint of lines, however all rotations are different. (See picture)
Is there a way with a LISP or something like that to align these blocks with the lines?
I could do them all manually, but it would be nice if there is another way to do this.
Thanks in advance. 🙂
ВeekeeCZ
Post a small sample dwg with states before and after.
komondormrex
hey, check this
(defun c:place_align_block_line (/ target_block_name line_data pick_point line_start_point line_end_point block_rotation)
  (setq target_block_name (vla-get-effectivename (vlax-ename->vla-object (car (entsel "\nSelect target block: ")))))
    (while t
    (setq line_data (entsel "\nSelect line end to place block at: ")
            pick_point (osnap (cadr line_data) "_endp")
            line_start_point (cdr (assoc 10 (entget (car line_data))))
          line_end_point (cdr (assoc 11 (entget (car line_data))))
            block_rotation (if (equal pick_point line_start_point 1e-3)
                   (angle line_end_point line_start_point)
                   (angle line_start_point line_end_point)
      (vla-insertblock (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
           (vlax-3d-point pick_point)
           target_block_name
           1 1 1
           block_rotation
Kent1Cooper
Yes, please post a sample drawing or image with before and after conditions, and using a Block with a more obvious direction if that mattersFor example, using one with an obvious "right way up," is this kind of orientation what you want [with the Text upright at zero rotation, but with the insertion's rotation determined by the other end of the Line], or should this Block be spun around 180° to read in the more upright direction?
Also, am I correct that you're talking about the rotations being calculated in the process of Inserting the Blocks, rather than fixing the roatations of Blocks that are already Inserted?
Kent Cooper, AIA
