ERROR AND MTEXT
ERROR AND MTEXT
etilley327KA
Message 1 of 24
ERROR AND MTEXT
etilley327KA
I really could use some help. I keep getting an error somewhere in my math functions, but I dont see it. Also, my mtext isnt working either. Im trying to add text with the variables.
(defun c:XC (/ tmn tdp mtof mtoc mdis slope mdn apron pt1)
            (setq tmn (getreal "\nEnter SLOPE tolerance: "))
            (setq tdp
              (cond
                (XSTRCASE(getreal "\nEnter standard drop or <Enter for 0.67>: "))
                (0.67)
            (setq mtof (getreal "\nEnter TOF: "))
            (setq mtoc (getreal "\nEnter TOC: "))
            (setq mdis (getreal "\nEnter Distance: "))
              (setq slope (rtos (* (/ (- mtof tdp mtoc) mdis) 100) 2 0))
              (setq mdn (- mtof (+ mtoc (* (/ tmn 100) mdis)) 0.375))
              (setq apron (- mtof (+ 0.375 mdn)))
                (if (< slope tmn)
                  (progn
                    (alert "Too High")
                    (command "mtext" (setq pt1 (getpoint "\nSelect Point: ") ) pt1 slope apron mtof mtoc mdis tdp "")
                    (command "mtext" (setq pt1 (getpoint "\nSelect Point: ") ) pt1 (strcat slope "%") "")
  (princ)
Replies (23)
Message 21 of 24
ВeekeeCZ
2 notes.
1) I would be careful with the debugger you are using. Even I don't know what values you enter, but in my opinion, there is no input that would bypass the syntax error in line 5. The screenshot from msg 5 does not make sense. VLIDE editor stops there with an error.
2) Post your final code - did you fix the syntax error in the COND function too?
Message 22 of 24
etilley327KA
            (setq tdp
              (cond
                ((getreal "\nEnter standard drop or <Enter for 0.67>: "))
                (0.67)
              (setq slope (* (/ (- mtof tdp mtoc) mdis) 100))
                (if (> slope tmn)
                  (progn
                    (alert "Too High")
                             (strcat (rtos slope 2 0) "%"
                              "\\PApron " (rtos apron 2 2)
                              "\\PTOF " (rtos mtof 2 2)
                              "\\PTOC " (rtos mtoc 2 2)
                              "\\PDist " (rtos mdis 2 2)
                              "\\PDrop " (rtos tdp 2 2)) "")
                    (command "mtext" (setq pt1 (getpoint "\nSelect Point: ") ) pt1 (strcat (rtos slope 2 0) "%") "")
  (princ)
Message 23 of 24
ВeekeeCZ
Approved.
Message 24 of 24
calderg1000
Regards @etilley327KA
Here you have another option. To use Strcat requires converting numbers to text. But Mtext also accepts integer or real numbers as an argument.
(defun c:XC(/ tmn tdp mtof mtoc mdis slope mdn apron pt1)
  (initget "S D")
  (setq opc (getkword "\nEnter (Standard Drop=0.67/Drop Value?)[S/D] <S>: "))
  (if (/= opc "D")
    (setq tdp 0.67)
    (setq tdp (getreal "\nEnter Drop Value: "))
  (if (< (fix slope) tmn)
    (progn
      (alert "Too High")
      (command "mtext"
               (setq pt1 (getpoint "\nSelect Point: "))
               pt1
               (strcat (rtos(fix slope)2 0) "%")
               apron
               mtof
               mtoc
               mdis
               tdp
    (command "mtext"
             pt1
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
