ERROR AND MTEXT
ERROR AND MTEXT
etilley327KA
Message 1 of 24
ERROR AND MTEXT
etilley327KA
I really could use some help. I keep getting an error somewhere in my math functions, but I dont see it. Also, my mtext isnt working either. Im trying to add text with the variables.
(defun c:XC (/ tmn tdp mtof mtoc mdis slope mdn apron pt1)
            (setq tmn (getreal "\nEnter SLOPE tolerance: "))
            (setq tdp
              (cond
                (XSTRCASE(getreal "\nEnter standard drop or <Enter for 0.67>: "))
                (0.67)
            (setq mtof (getreal "\nEnter TOF: "))
            (setq mtoc (getreal "\nEnter TOC: "))
            (setq mdis (getreal "\nEnter Distance: "))
              (setq slope (rtos (* (/ (- mtof tdp mtoc) mdis) 100) 2 0))
              (setq mdn (- mtof (+ mtoc (* (/ tmn 100) mdis)) 0.375))
              (setq apron (- mtof (+ 0.375 mdn)))
                (if (< slope tmn)
                  (progn
                    (alert "Too High")
                    (command "mtext" (setq pt1 (getpoint "\nSelect Point: ") ) pt1 slope apron mtof mtoc mdis tdp "")
                    (command "mtext" (setq pt1 (getpoint "\nSelect Point: ") ) pt1 (strcat slope "%") "")
  (princ)
Replies (23)
Message 2 of 24
ВeekeeCZ
Comparing "slope" being a string to "tmn" being a real...
Message 3 of 24
ВeekeeCZ
slope apron mtof mtoc mdis tdp ... all have to be STRINGs and (strcat .... ) together into one string.
Message 4 of 24
ВeekeeCZ
XSTRCASE is something undocumented that I don't know. What is it? That could be your issue - if that returns a string.
Edit:
(xstrcase) An international-friendly version of (strcase).
Message 5 of 24
etilley327KA
Someone helped me with that, it looks to be something similar to strcase, but I can't see the difference. I guess ill just switch it to strcase.
Message 6 of 24
ВeekeeCZ
I would remove it. STRCASE does not make sense to use there.
Message 7 of 24
etilley327KA
Slope should be a real, where did I switch it? Also, if I cant use strcat, how do I add text to the variable in my mtext?
Message 8 of 24
ВeekeeCZ
2nd... Why can not you? IMHO you can, but first you need to convert all the reals to strings.
Message 9 of 24
etilley327KA
OK, so I just need to convert all my reals to strings, got it. On my math function, even when I remove the rtos I still get an error, do you know why?
Message 10 of 24
ВeekeeCZ
Did you remove that xstrcase?
  (setq tdp (cond ((getreal "\nEnter standard drop or <0.67>: "))
		  (0.67)))
  (setq slope (* (/ (- mtof tdp mtoc) mdis) 100))
  (if (< slope tmn)
    (progn
      (alert "Too High")
      (command "mtext" (setq pt1 (getpoint "\nSelect Point: ")) pt1 (strcat (rtos slope) ", " (rtos apron) ", " (rtos mtof) ", " (rtos mtoc) ", " (rtos mdis) ", " (rtos tdp) "" ""))
    (command "mtext" (setq pt1 (getpoint "\nSelect Point: ") ) pt1 (strcat slope "%") "" "")
  (princ)
I didn't check the math, just the syntax.
Message 11 of 24
Kent1Cooper
.... even when I remove the rtos I still get an error, do you know why?
What error?  Show the way the edited code line ended up.
Kent Cooper, AIA
Message 12 of 24
etilley327KA
            (setq tdp
              (cond
                (STRCASE(getreal "\nEnter standard drop or <Enter for 0.67>: "))
                (0.67)
                (if (< slope tmn)
                  (progn
                    (alert "Too High")
                             (strcat (rtos slope 2 0) "%"
                              "\\PApron " (rtos apron 2 2)
                              "\\PTOF " (rtos mtof 2 2)
                              "\\PTOC " (rtos mtoc 2 2)
                              "\\PDist " (rtos mdis 2 2)
                              "\\PDrop " (rtos tdp 2 2)) "")
                    (command "mtext" (setq pt1 (getpoint "\nSelect Point: ") ) pt1 (strcat (rtos slope 2 0) "%") "")
  (princ)
Message 13 of 24
ВeekeeCZ
Ok, I guess it's just me... Would you explain to me what purpose serves the STRCASE there?
Message 14 of 24
Kent1Cooper
This is why I asked what the error was [saying "I still get an error" is never enough information].  It's apparently not from the removing of the (rtos) part, but from the attempt to change the case of a number, or of nil if you hit Enter to accept the default.
Kent Cooper, AIA
Message 15 of 24
etilley327KA
bad argument type: numberp: nil :error#2
Message 16 of 24
etilley327KA
Not really sure. I was trying to ask for a number but have a standard input if the user didnt have one.
Message 17 of 24
ВeekeeCZ
Well, it's your code. Who else should know?! If you don't know something, look in HELP.
Message 18 of 24
etilley327KA
I removed the stcase, thanks.
Message 19 of 24
Kent1Cooper
Even if it were possible to make a number uppercase, you would be missing a set of parentheses:
              (cond
                ((STRCASE(getreal "\nEnter standard drop or <Enter for 0.67>: ")))
                (0.67)
Kent Cooper, AIA
Message 20 of 24
etilley327KA
Yeah, it seems that variable was causing the problem. Thanks
