entmake aligned dimension text reversed
diegolopezsilanes
diegolopezsilanes
Hello, I'm doing a program that creates aligned dimensions, but I create them with the text aligned in reverse, that is, on the other side of the dimension line, as shown in the attached photo
Another issue is that I can not make them polyvalent for horizontal or vertical dimensioning
Thank you very much
here is the code i'm working with:
(DEFUN C:ddi ()
(SETQ ptStart (getpoint "\nPTO1  "))
(SETQ ptEnd (getpoint "\nPTO2  "))
(SETQ ptLoc (getpoint "\nPTO3  "))
(ENTMAKE (LIST
(CONS 0 "DIMENSION")
(CONS 100 "AcDbEntity")
(CONS 100 "AcDbDimension")
(CONS 10 ptLoc)
(CONS 11 '(0 0 0));;TRATAR DE QUITAR
(CONS 70 0)
(CONS 71 5)
'(100 . "AcDbAlignedDimension") ; added
(CONS 13 ptStart)
(CONS 14 ptEnd)
;;;(CONS 50 dimRot)
'(50 . 1.5708)
(CONS 100 "AcDbRotatedDimension")
Moshe-A
@diegolopezsilanes hi,
instead this:
'(50 . 1.5708)
do this:
(cons 50 (/ pi 2))
diegolopezsilanes
Thanks Moshe
