grread dimension entmake lee mac 3p rectangle customization
diegolopezsilanes
diegolopezsilanes
Hi, I'm triyng to modify the code of LEE MAC  3-point Rectangle that enables the user to dynamically construct a rectangle defined by three supplied points for making aligned dimensions with previsualization.
I thought that modifiyng the entmake function could work in some way but it doesnt
i`ll thank at least any advise
here is my entmake
        (entmake
            (list
				(CONS 0 "DIMENSION")
				(CONS 100 "AcDbEntity")
				(CONS 100 "AcDbDimension")
				;;;;(CONS 10 ptLoc )
				(cons 010 (trans PT3 1 ocs))
				(CONS 11 '(0 0 0));;TRATAR DE QUITAR
				(CONS 70 0)
				(CONS 71 5)
				'(100 . "AcDbAlignedDimension") ; added
				;;(CONS 13 ptStart)
				(CONS 13 (trans PT1 1 ocs))
				;;(CONS 14 ptEnd)
				(CONS 14 (trans PT2 1 ocs))
				;;;(CONS 50 dimRot)
				(cons 50 (/ pi 2))
				(CONS 100 "AcDbRotatedDimension")
                (cons 210 ocs)
and here is the link  and the code of lee mac
http://www.lee-mac.com/3pointrectangle.html
;;-----------------------=={ 3-Point Rectangle }==----------------------;;
;;  This program enables the user to dynamically construct a rectangle  ;;
;;  defined by three supplied points.                                   ;;
;;  The program offers two commands: '3PR' and '3PRD' which represent   ;;
;;  a standard & dynamic version of the program respectively.           ;;
;;  Upon issuing either command at the AutoCAD command-line, the user   ;;
;;  is first prompted to specify two points defining one of the two     ;;
;;  pairs of parallel sides of the resulting rectangle.                 ;;
;;  Following valid responses to these prompts, the user is then        ;;
;;  prompted for a third point to determine the length and direction    ;;
;;  of the second pair of edges, which are constructed perpendicular    ;;
;;  to the edges defined by the first two points.                       ;;
;;  If the dynamic command is used ('3PRD') the program will display a  ;;
;;  real-time preview of the resulting rectangle whilst the user is     ;;
;;  prompted for the third point.                                       ;;
;;  The user may exit the program at any time by pressing 'Enter' or    ;;
;;  right-clicking at any prompt.                                       ;;
;;  Following valid specification of all three points, the program      ;;
;;  will proceed to construct the defined rectangle using an            ;;
;;  LWPolyline object.                                                  ;;
;;  The dynamic version of the program utilises my GrSnap utility to    ;;
;;  enable full Object Snap functionality during the dynamic prompt.    ;;
;;  The latest version and full documentation for this application may  ;;
;;  be found at: http://www.lee-mac.com/grsnap.html                     ;;
;;  Finally, this program has been designed to perform successfully     ;;
;;  under all UCS & View settings.                                      ;;
;;  Author:  Lee Mac, Copyright © 2013  -  www.lee-mac.com              ;;
;;  Version 1.0    -    2013-12-27                                      ;;
;;  First release.                                                      ;;
(defun c:3pr  nil (3p-rec nil)) ;; Standard version
(defun c:3prd nil (3p-rec  t )) ;; Dynamic version
(defun 3p-rec ( dyn / *error* gr1 gr2 lst msg ocs osf osm pt1 pt2 pt3 pt4 pt5 pt6 str tmp vec )
    (defun *error* ( msg )
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
            (princ (strcat "\nError: " msg))
        (redraw) (princ)
    (if
        (and
            (setq pt1 (getpoint "\nSpecify 1st point: "))
            (setq pt2 (getpoint "\nSpecify 2nd point: " pt1))
            (or   dyn (setq pt3 (getpoint "\nSpecify 3rd point: " pt1)))
            (setq vec (trans (mapcar '- pt2 pt1) 1 0 t)
                  ocs (trans '(0.0 0.0 1.0) 1 0 t)
                  pt4 (trans pt1 1 vec)
                  pt5 (trans pt2 1 vec)
            (if dyn
                (progn
                    (setq osf (LM:grsnap:snapfunction)
                          osm (getvar 'osmode)
                          msg "\nSpecify 3rd point: "
                          str ""
                    (princ msg)
                    (while
                        (progn
                            (setq gr1 (grread t 15 0)
                                  gr2 (cadr gr1)
                                  gr1 (car  gr1)
                            (cond
                                (   (or (= 5 gr1) (= 3 gr1))
                                    (redraw)
                                    (osf gr2 osm)
                                    (setq pt6 (trans gr2 1 vec))
                                    (mapcar '(lambda ( a b ) (grdraw a b 1 1))
                                        (setq lst
                                            (list pt1 pt2
                                                (trans (list (car pt6) (cadr pt6) (caddr pt5)) vec 1)
                                                (trans (list (car pt6) (cadr pt6) (caddr pt4)) vec 1)
                                        (cons (last lst) lst)
                                    (= 5 gr1)
                                (   (= 2 gr1)
                                    (cond
                                        (   (= 6 gr2)
                                            (if (zerop (logand 16384 (setq osm (setvar 'osmode (boole 6 16384 (getvar 'osmode))))))
                                                (princ "\n<Osnap on>")
                                                (princ "\n<Osnap off>")
                                            (princ msg)
                                        (   (= 8 gr2)
                                            (if (< 0 (strlen str))
                                                (progn
                                                    (princ "\010\040\010")
                                                    (setq str (substr str 1 (1- (strlen str))))
                                            t
                                        (   (< 32 gr2 127)
                                            (setq str (strcat str (princ (chr gr2))))
                                        (   (member gr2 '(13 32))
                                            (cond
                                                (   (= "" str) nil)
                                                (   (setq gr2 (LM:grsnap:parsepoint pt1 str))
                                                    (setq osm 16384)
                                                    nil
                                                (   (setq tmp (LM:grsnap:snapmode str))
                                                    (setq osm tmp
                                                          str ""
                                                (   (setq str "")
                                                    (princ (strcat "\n2D / 3D Point Required." msg))
                    (if (listp gr2)
                        (setq pt6 (trans (osf gr2 osm) 1 vec))
                (setq pt6 (trans pt3 1 vec))
        (entmake
            (list
               '(000 . "LWPOLYLINE")
               '(100 . "AcDbEntity")
               '(100 . "AcDbPolyline")
               '(090 . 4)
               '(070 . 1)
                (cons 010 (trans pt1 1 ocs))
                (cons 010 (trans pt2 1 ocs))
                (cons 010 (trans (list (car pt6) (cadr pt6) (caddr pt5)) vec ocs))
                (cons 010 (trans (list (car pt6) (cadr pt6) (caddr pt4)) vec ocs))
                (cons 210 ocs)
    (redraw) (princ)
;; Object Snap for grread: Snap Function  -  Lee Mac
;; Returns: [fun] A function requiring two arguments:
;; p - [lst] UCS Point to be snapped
;; o - [int] Object Snap bit code
;; The returned function returns either the snapped point (displaying an appropriate snap symbol)
;; or the supplied point if the snap failed for the given Object Snap bit code.
(defun LM:grsnap:snapfunction ( )
    (eval
        (list 'lambda '( p o / q )
            (list 'if '(zerop (logand 16384 o))
                (list 'if
                   '(setq q
                        (cdar
                            (vl-sort
                                (vl-remove-if 'null
                                    (mapcar
                                        (function
                                            (lambda ( a / b )
                                                (if (and (= (car a) (logand (car a) o)) (setq b (osnap p (cdr a))))
                                                    (list (distance p b) b (car a))
                                            (0001 . "_end")
                                            (0002 . "_mid")
                                            (0004 . "_cen")
                                            (0008 . "_nod")
                                            (0016 . "_qua")
                                            (0032 . "_int")
                                            (0064 . "_ins")
                                            (0128 . "_per")
                                            (0256 . "_tan")
                                            (0512 . "_nea")
                                            (2048 . "_app")
                                            (8192 . "_par")
                               '(lambda ( a b ) (< (car a) (car b)))
                    (list 'LM:grsnap:displaysnap '(car q)
                        (list 'cdr
                            (list 'assoc '(cadr q)
                                (list 'quote
                                    (LM:grsnap:snapsymbols
                                        (atoi (cond ((getenv "AutoSnapSize")) ("5")))
                        (LM:OLE->ACI
                            (if (= 1 (getvar 'cvport))
                                (atoi (cond ((getenv "Layout AutoSnap Color")) ("117761")))
                                (atoi (cond ((getenv  "Model AutoSnap Color")) ("104193")))
           '(cond ((car q)) (p))
;; Object Snap for grread: Display Snap  -  Lee Mac
;; pnt - [lst] UCS point at which to display the symbol
;; lst - [lst] grvecs vector list
;; col - [int] ACI colour for displayed symbol
;; Returns nil
(defun LM:grsnap:displaysnap ( pnt lst col / scl )
    (setq scl (/ (getvar 'viewsize) (cadr (getvar 'screensize)))
          pnt (trans pnt 1 2)
    (grvecs (cons col lst)
        (list
            (list scl 0.0 0.0 (car  pnt))
            (list 0.0 scl 0.0 (cadr pnt))
            (list 0.0 0.0 scl 0.0)
           '(0.0 0.0 0.0 1.0)
;; Object Snap for grread: Snap Symbols  -  Lee Mac
;; p - [int] Size of snap symbol in pixels
;; Returns: [lst] List of vector lists describing each Object Snap symbol
(defun LM:grsnap:snapsymbols ( p / -p -q -r a c i l q r )
    (setq -p (- p) q (1+  p)
          -q (- q) r (+ 2 p)
          -r (- r) i (/ pi 6.0)
           a 0.0
    (repeat 12
        (setq l (cons (list (* r (cos a)) (* r (sin a))) l)
              a (- a i)
    (setq c (apply 'append (mapcar 'list (cons (last l) l) l)))
    (list
        (list 1
            (list -p -p) (list p -p) (list p -p) (list p p) (list p p) (list -p p) (list -p p) (list -p -p)
            (list -q -q) (list q -q) (list q -q) (list q q) (list q q) (list -q q) (list -q q) (list -q -q)
        (list 2
            (list -r -q) (list 0  r) (list 0  r) (list r -q)
            (list -p -p) (list p -p) (list p -p) (list 0  p) (list 0  p) (list -p -p)
            (list -q -q) (list q -q) (list q -q) (list 0  q) (list 0  q) (list -q -q)
        (cons 4 c)
        (vl-list* 8 (list -r -r) (list r r) (list r -r) (list -r r) c)
        (list 16
            (list p 0) (list 0 p) (list 0 p) (list -p 0) (list -p 0) (list 0 -p) (list 0 -p) (list p 0)
            (list q 0) (list 0 q) (list 0 q) (list -q 0) (list -q 0) (list 0 -q) (list 0 -q) (list q 0)
            (list r 0) (list 0 r) (list 0 r) (list -r 0) (list -r 0) (list 0 -r) (list 0 -r) (list r 0)
        (list 32
            (list  r r) (list -r -r) (list  r q) (list -q -r) (list  q r) (list -r -q)
            (list -r r) (list  r -r) (list -q r) (list  r -q) (list -r q) (list  q -r)
        (list 64
            '( 0  1) (list  0  p) (list  0  p) (list -p  p) (list -p  p) (list -p -1) (list -p -1) '( 0 -1)
            '( 0 -1) (list  0 -p) (list  0 -p) (list  p -p) (list  p -p) (list  p  1) (list  p  1) '( 0  1)
            '( 1  2) (list  1  q) (list  1  q) (list -q  q) (list -q  q) (list -q -2) (list -q -2) '(-1 -2)
            '(-1 -2) (list -1 -q) (list -1 -q) (list  q -q) (list  q -q) (list  q  2) (list  q  2) '( 1  2)
        (list 128
            (list (1+ -p) 0) '(0 0) '(0 0) (list 0 (1+ -p))
            (list (1+ -p) 1) '(1 1) '(1 1) (list 1 (1+ -p))
            (list -p q) (list -p -p) (list -p -p) (list q -p)
            (list -q q) (list -q -q) (list -q -q) (list q -q)
        (vl-list* 256 (list -r r)  (list r r) (list -r (1+ r)) (list r (1+ r)) c)
        (list 512
            (list -p -p) (list  p -p) (list -p  p) (list p p) (list -q -q) (list  q -q)
            (list  q -q) (list -q  q) (list -q  q) (list q q) (list  q  q) (list -q -q)
        (list 2048
            (list   -p     -p) (list    p      p) (list   -p      p) (list    p     -p)
            (list (+ p 05) -p) (list (+ p 06) -p) (list (+ p 05) -q) (list (+ p 06) -q)
            (list (+ p 09) -p) (list (+ p 10) -p) (list (+ p 09) -q) (list (+ p 10) -q)
            (list (+ p 13) -p) (list (+ p 14) -p) (list (+ p 13) -q) (list (+ p 14) -q)
        (list 8192 (list r 1) (list -r -q) (list r 0) (list -r -r) (list r q) (list -r -1) (list r r) (list -r 0))
;; Object Snap for grread: Parse Point  -  Lee Mac
;; bpt - [lst] Basepoint for relative point input, e.g. @5,5
;; str - [str] String representing point input
;; Returns: [lst] Point represented by the given string, else nil
(defun LM:grsnap:parsepoint ( bpt str / str->lst lst )
    (defun str->lst ( str / pos )
        (if (setq pos (vl-string-position 44 str))
            (cons (substr str 1 pos) (str->lst (substr str (+ pos 2))))
            (list str)
    (if (wcmatch str "`@*")
        (setq str (substr str 2))
        (setq bpt '(0.0 0.0 0.0))
    (if
        (and
            (setq lst (mapcar 'distof (str->lst str)))
            (vl-every 'numberp lst)
            (< 1 (length lst) 4)
        (mapcar '+ bpt lst)
;; Object Snap for grread: Snap Mode  -  Lee Mac
;; str - [str] Object Snap modifier
;; Returns: [int] Object Snap bit code for the given modifier, else nil
(defun LM:grsnap:snapmode ( str )
    (vl-some
        (function
            (lambda ( x )
                (if (wcmatch (car x) (strcat (strcase str t) "*"))
                    (progn
                        (princ (cadr x)) (caddr x)
            ("endpoint"      " of " 00001)
            ("midpoint"      " of " 00002)
            ("center"        " of " 00004)
            ("node"          " of " 00008)
            ("quadrant"      " of " 00016)
            ("intersection"  " of " 00032)
            ("insert"        " of " 00064)
            ("perpendicular" " to " 00128)
            ("tangent"       " to " 00256)
            ("nearest"       " to " 00512)
            ("appint"        " of " 02048)
            ("parallel"      " to " 08192)
            ("none"          ""     16384)
;; OLE -> ACI  -  Lee Mac
;; Args: c - [int] OLE Colour
(defun LM:OLE->ACI ( c )
    (apply 'LM:RGB->ACI (LM:OLE->RGB c))
;; OLE -> RGB  -  Lee Mac
(defun LM:OLE->RGB ( c )
    (mapcar '(lambda ( x ) (lsh (lsh (fix c) x) -24)) '(24 16 8))
;; RGB -> ACI  -  Lee Mac
;; Args: r,g,b - [int] Red, Green, Blue values
(defun LM:RGB->ACI ( r g b / c o )
    (if (setq o (vla-getinterfaceobject (LM:acapp) (strcat "autocad.accmcolor." (substr (getvar 'acadver) 1 2))))
        (progn
            (setq c (vl-catch-all-apply '(lambda ( ) (vla-setrgb o r g b) (vla-get-colorindex o))))
            (vlax-release-object o)
            (if (vl-catch-all-error-p c)
                (prompt (strcat "\nError: " (vl-catch-all-error-message c)))
                c
;; Application Object  -  Lee Mac
;; Returns the VLA Application Object
(defun LM:acapp nil
    (eval (list 'defun 'LM:acapp 'nil (vlax-get-acad-object)))
    (LM:acapp)
(vl-load-com)
(princ
    (strcat
        "\n:: 3P-Rec.lsp | Version 1.0 | \\U+00A9 Lee Mac "
        (menucmd "m=$(edtime,0,yyyy)")
        " www.lee-mac.com ::"
        "\n:: \"3PR\" - Standard | \"3PRD\" - Dynamic ::"
(princ)
;;                             End of File                              ;;
CADaSchtroumpf
Change in the code of lee Mac
              (entmake
                  (list
                     '(090 . 4)
                     '(070 . 1)
                      (cons 210 ocs)
by
            (progn
              (entmake
                  (list
                     '(090 . 4)
                     '(070 . 1)
                      (cons 210 ocs)
              (entmake
                (list
                  '(0 . "DIMENSION")
                  (cons 8 (getvar "CLAYER"))
                  '(100 . "AcDbDimension")
                  '(280 . 0)
                  (cons 10
                    (polar
                      (mapcar '* (mapcar '+ (trans pt1 1 ocs) (trans pt2 1 ocs)) '(0.5 0.5 0.5))
                      (angle (trans (list (car pt6) (cadr pt6) (caddr pt5)) vec ocs) (trans pt2 1 ocs))
                      (* (distance (trans pt2 1 ocs) (trans (list (car pt6) (cadr pt6) (caddr pt5)) vec ocs)) 0.5)
                  (cons 11
                    (polar
                      (trans pt2 1 ocs)
                  '(70 . 1)
                  '(1 . "")
                  '(71 . 5)
                  '(72 . 1)
                  '(41 . 1.0)
                  '(3 . "Standard")
                  (cons 210 ocs)
                  (cons 13 (trans pt1 1 ocs))
                  (cons 14 (trans pt2 1 ocs))
                  '(40 . 0)
                  '(50 . 0.0)
Don't forget to add the (progn  (entmake POLYLINE) & (entmake DIMENSION))
Add a new (entmake DIMENSION) at the progn if you want the other side, you have the model!
