TO AVOID CASE SENSITIVE IN TEXT SELECTION FROM LISP
Message 1 of 13
Dear Helpers,
I got a lisp code that can select text elements in entire drawing by user input. But it's not working for case sensitive letters and also not asking for window selection. Please do needful.
(defun C:SWT (/ str ss) ; = Find String(s) by Content
(setq str (getstring "\nYour [full or partial] string content to search for: "))
(if (setq ss (ssget "_X" (list (cons 0 "*TEXT") (cons 1 (strcat "*" str "*")) (cons 410 (getvar 'ctab)))))
(sssetfirst nil ss); select/highlight/grip
); if
); defun
T.Brahmanandam.
Replies (12)
Message 2 of 13
_gile
Try this:
(defun C:SWT (/ str ss i txt)
  (if
    (and
      (setq ss (ssget '((0 . "*TEXT"))))
     (progn
       (setq str (strcat "*" (strcase str) "*"))
       (repeat (setq i (sslength ss))
         (setq txt (ssname ss (setq i (1- i))))
         (if (not (wcmatch (strcase (cdr (assoc 1 (entget txt)))) str))
           (ssdel txt ss)
       (sssetfirst nil ss)
  (princ)
Gilles Chanteau
GileCAD
GitHub
Message 3 of 13
Excellent Sir,
Could you please update to block selections also, as like you ddi for text selection?
T.Brahmanandam
Message 4 of 13
Kent1Cooper
If you are asking that for case-sensitivity, be aware that Block [and Layer] names in (ssget) filter lists are not  case-sensitive the way text-string content is.
(if
  (and
    (setq blkname (getstring "\nBlock name to find insertions of: "))
    (setq blks (ssget (list (cons 2 blkname))))
  (sssetfirst nil blks)
It doesn't matter if you enter the Block name in a different CaSe CoMbInAtIoN from the way it is in the Block table -- it will find them.
Kent Cooper, AIA
Message 5 of 13
Thank you Sir,
I have updated the code with your hints, but not working to select the blocks with wildcart match.
(defun C:SBT (/ blkname blks i txt)
(if
(and
(progn
(setq blkname (strcat "*" (strcase blkname) "*"))
(repeat (setq i (sslength blks))
(setq txt (ssname blks (setq i (1- i))))
(if (not (wcmatch (strcase (cdr (assoc 1 (entget txt)))) blkname))
(ssdel txt blks)
(princ)
Message 6 of 13
_gile
if you want to get help, you have to clearly explain what you mean with "select the blocks with wildcart match".
Gilles Chanteau
GileCAD
GitHub
Message 7 of 13
Sir,
If we have some blocks in drawing as below
"LED LAMP-A",
"LED LAMP-B"
"CFL LAMP-A"
"CFL LAMP-B"
"TUBE LIGHT-A"
"TUBE LIGHT-B"
1) If user give user input as TUBE, then all blocks which contains name as TUBE should select. In this case all TUBE LIGHT-A & TUBE LIGHT-B should be selected.
2) If user give user input as CFL, then all blocks which contains name as TUBE should select. In this case all CFL LAMP-A & CFL LAMP-B should be selected.
3) If user give user input as LED, then all blocks which contains name as TUBE should select. In this case all LED LAMP-A & LED LAMP-B should be selected.
Sir, I think this explanation gives better idea to you for my requirement. Advanced thank you sir.
Message 8 of 13
dbhunia
Try this
(setq blks (ssget "_A" (list (2 . "*blkname*"))))
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 9 of 13
dlanorh
This is correct if the supplied text is not at the start or the end of the name
It will not find blocks that start with blkname or end with blkname as it is used with wcmatch and there are no characters before in the start case or after in the end case
If blkname text is at the start of the blockname string then this has to be changed to
(setq blkname (strcat (strcase blkname) "*"))
If blkname text is at the end of the blockname string then this has to be changed to
(setq blkname (strcat "*" (strcase blkname)))
I am not one of the robots you're looking for
Message 10 of 13
Kent1Cooper
Not true.  The  *  wildcard stands in for any character or combination of characters, including no  characters.  It is very  commonly used in a situation where it does  find things in which there are no characters in place of the  *  wildcard:
(ssget "_X" '((0 . "*POLYLINE")))
is used all the time to find Polylines of any variety, and it finds both LWPOLYLINE entities for which the LW are covered by the  * , and POLYLINE entities for which there are no characters in place of the  * .  Likewise, *TEXT is used to find both TEXT and MTEXT entities.
Easy proof:
Command: (wcmatch "TEST" "TEST*")
T
Command: (wcmatch "TEST" "*TEST")
T
Command: (wcmatch "TEST" "*TEST*")
T
Kent Cooper, AIA
Message 11 of 13
Kent1Cooper
Try it this way [untested]:
  (if
    (and
      (setq blkpart (getstring "\nPartial Block name for insertions of Blocks containing it: "))
      (setq blks (ssget (list (cons 2 (strcat "*" (strcase blkpart) "*")))))
  (princ)
Kent Cooper, AIA
Message 12 of 13
Thank you Sir. It's working fine.
Message 13 of 13
dlanorh
@Kent1Cooper wrote:
Easy proof:
T
T
T
You are correct Robot Happy I'm obviously having another senior moment and confusing this with something else. Robot Embarassed
