entlast on area command
I really don't understand why entlast doesn't work with the area command. The command stops after the boundary command...
(defun c:superficie (/ ent center)
(setq center (getpoint "Specify internal point"))
(command "_boundary" center "")
(setq ent (entlast))
(command "_area" "_o" ent)
(princ)
Moshe-A
maybe you do not need (setq ent (entlast))
try this:
(command "_area" "_object" "_last")
Moshe
it doesn't work...
doaiena
Try this:
(defun c:test (/ ent center)
(princ (strcat "\n" (rtos (vlax-get-property (vlax-ename->vla-object (entlast)) 'area) 2 4)))
(princ)
john.uhden
It worked for me in 2002.
John F. Uhden
