Enable to get custom command
mahesh.thokeZF27U
mahesh.thokeZF27U
I have created command method in .NET core class library project .
Load DLL using NETLOAD command but could not get specified command method.
Program works when using .NET framework 4.5 project type.
john.uhden
Sorry, but this is the AutoLisp/Visual Lisp subforum.  Most of us here are considered as mere neanderthals to those who meddle in .NET.  Try asking the check-out person at Acme.  We only create solutions that work, and we avoid errors.
John F. Uhden
_gile
You can only use the AutoCAD .NET API with Windows and it requires the .NET Framework instead of .NET Core.
You should have a look at this documentation and post your question about AutoCAD .NET cutomization in the .NET forum.
Gilles Chanteau
GileCAD
GitHub
