echo suppression
echo suppression
zph
echo suppression
zph
Good day!
Just a question for you guys.
Is there a way to suppress the output of the OVERKILL command in autolisp?
Here is a simple routine as an example:
(defun c:demo ()
(setvar "cmdecho" 0)
(setq oldOSmode (getvar "osmode"))
(setvar "osmode" 0)
(command "-overkill" (ssget) "" "")
(setvar "cmdecho" 1)
(setvar "osmode" oldOSmode)
(princ)
) ;demo
And this what ACAD returns:
Current settings: Tolerance=0.000001, Ignore=None, Optimize polylines=Yes, Combine partial overlap=Yes, Combine end-to-end=Yes
0 duplicate(s) deleted
0 overlapping object(s) or segment(s) deleted
I'd like to be able to suppress the 'current settings' part from the command line, ideally.  I don't mind keeping the quantity of objects deleted.
Is this possible?
scot-65
NOMUTT 0/1
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
zph
Thanks for the reply, scot-65. Resetting the system variable nomutt didn't suppress the overkill return, though.
scot-65
The only other way I know to keep the command line
quiet is to make a command in the CUI with the prefix
^Q or ^P in the macro string.
untested.
Scot-65
IconSystem
There's the same issue with the ATTSYNC command which regardless of NOMUTT and CMDECHO settings, always prompts "ATTSYNC complete."
Annoying.
Regards, Chris
