API of BOM & FORM command
Message 1 of 1
I want to know if there is an API available for "BMFORM" command & "BMBOM" command ? After selecting 3dSolid figure using AcDbEntity, how I can save the entity as a component in some particular folder with the same name as its layer name pro-grammatically? After converting into component how to get BOM for that component pro-grammatically?
I used WBLOCK command and created a block reference, But the problem is that WBLOCK doesn’t treat the converted Block as component part of an assembly.
The individual components converted into Wblock are not part of the BOM (Bill of Materials).
I have attached 2 images describing my requirements:
Not required:- The First Image (ComponentsCreatedUsingwblock.JPG) refers to the BOM created after converting the individual components using WBLOCK.
Required:- The Second Image (ComponentsUsingBmform.JPG) refers to the BOM created after converting the individual components using BMFORM.
Please give a suggestion to automate BOM Command using ARX API.
Replies (0)
