Drawing Utilities > Drawing Properties
Message 1 of 19
Hi
I am trying add (vl-filename-base (getvar "dwgname"))) in below list, please help on this.
(defun c:dProps (/ dProps dProp)
(vl-load-com)
(setq acadObject (vlax-get-acad-object))
(setq acadDocument (vla-get-ActiveDocument acadObject))
   ;;Get the SummaryInfo
   (setq dProps (vlax-get-Property acadDocument 'SummaryInfo))
   ;;Add an entry to the "Custom" tab
   (vla-addcustominfo dProps "CONSULTANT" "DEWAN ARCHITECTS & ENGINEERS")
   (vla-addcustominfo dProps "DRAWING NUMBER" "(vl-filename-base (getvar "dwgname")))")
   (vla-addcustominfo dProps "DATE" "24/01/2016")
   (vla-addcustominfo dProps "REVISION NUMBER" "0")
   (vla-addcustominfo dProps "SITE LOCATION" "ABU DHABI REEM ISLAND SECTOR RR1 PLOT C5")
   (command "-layout" "rename" "" (vl-filename-base (getvar "dwgname")))
   (princ)
Replies (18)
Message 2 of 19
hmsilva
Try
   (vl-load-com)
   (vla-addcustominfo dProps "DRAWING NUMBER" (vl-filename-base (getvar "dwgname")))
   (princ)
Hope this helps,
Henrique
Message 3 of 19
Hi
Still showing ; error: Automation Error. Duplicate key
Message 4 of 19
hmsilva
@Anonymous wrote:
Hi
You are trying to add a new key, if already exists, will error...
You'll have to test if exist, the add or set Custom....
Or, simply remove custom infos before adding new ones...
   (vl-load-com)
   ;; remove custom infos
   (repeat (setq n (vla-NumCustomInfo dProps))
      (vla-RemoveCustomByIndex dProps (setq n (1- n)))
   (princ)
Hope this helps,
Henrique
Message 5 of 19
Thanks....
Message 6 of 19
hmsilva
@Anonymous wrote:
Thanks....
You're welcome, snsdxb!
Glad I could help
Henrique
Message 7 of 19
BeKirra
@hmsilva wrote:
@Anonymous wrote:
Hi
Hope this helps,
Henrique
Hi Henrique / members,
I found this old thread and would like to know how to test if a key exists.
Thanks.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 8 of 19
hmsilva
Thanks.
Hi BeKirra,
one way,
;; Change custom property
;; prop = custom property Name as a string
;; newvalue = New custom property Value as a string
;; usage (ch_info "Location Code" "123-XYZ")
(vl-load-com)
(defun ch_info (prop newvalue / a b proplst suminfo)
  (setq	suminfo	(vla-get-SummaryInfo
		  (vla-get-ActiveDocument (vlax-get-acad-object))
  (if (> (setq n (vla-NumCustomInfo suminfo)) 0)
    (repeat n
      (vla-GetCustomByIndex suminfo (setq n (1- n)) 'a 'b)
      (setq proplst (cons (list n a b) proplst))
  (if (vl-position prop (mapcar 'cadr proplst));<<< the test...
    (vla-SetCustomByKey suminfo prop newvalue)
  (princ)
Hope this helps,
Henrique
Message 9 of 19
BeKirra
Thanks Henrique.
It seems to work. But this line doesn't actually compare the user input and the existing key:
I know it will return the existing key postion value in the list if it is found.
How to rewrite it if I would like to compare the name of the existing key and user input?
Thanks for your help.
X² + Y² = C²
Message 10 of 19
hmsilva
@BeKirra wrote:
Thanks Henrique.
You're welcome, BeKirra
If I understood...
;; Test custom property Name
;; usage (prop? "Property Name")
;; Return T if true, otherwise nil
(vl-load-com)
(defun prop? (prop / a b flag proplst suminfo)
    (repeat n
    (setq flag T)
    flag
Hope this helps,
Henrique
Message 11 of 19
BeKirra
Thanks again.
I woulk like to know how to get a property name from the list.
For example, the format of the list of existing drawing property is:
((0 DWGprop_1 Value_1) (1 DWGprop_2 Value_2) (2 DWGprop_3 Value_3) …)
Supposed the name of "DWGprop_3" from the list is the same as user's input.
How do I take it out from the list so I can compare it with the user input? like:
(if (eq UserInput DWGprop_3)
 Thanks.
X² + Y² = C²
Message 12 of 19
hmsilva
@BeKirra wrote:
Thanks again.
 Thanks.
BeKirra,
with the 'prop?' function, we can test if the UserInput is one of the propreties Name.
_$ (setq UserInput (getstring))
"DWGprop_3"
_$ (prop? UserInput)
T
But if you need to get Name and Value from property...
Perhaps something like this...
;; Get custom property Index, Name and Value
;; Return a list with three elements
;; nth 0 the property Index
;; nth 1 the property Name
;; nth 2 the property Value
;; otherwise nil
(vl-load-com)
(defun get_prop (prop / a b proplst result suminfo)
    (repeat n
  (if (setq result (vl-member-if (function (lambda (a) (equal (cadr a) UserInput))) proplst))
    (setq result (car result))
    result
Test...
_$ (setq UserInput "DWGprop_3")
"DWGprop_3"
_$ (get_prop UserInput)
(2 "DWGprop_3" "789")
_$
Hope this helps,
Henrique
Message 13 of 19
BeKirra
Incredible. It works great!
I have tried to use "vl-member-if" without success.
Thanks again for your help.
X² + Y² = C²
Message 14 of 19
BeKirra
Another question:
It seems the name of property in the "dwgprops" pop-up is case sensitive.
For example, if there is an existing name of "Sales", the user input has to be exactly the same. All other cases (i.e. "sales", "SALES", etc) this line will return "nil":
How to fix it? Thanks.
X² + Y² = C²
Message 15 of 19
hmsilva
You're welcome, BeKirra!
Glad I could help
@BeKirra wrote:
Another question:
 Try
(vl-member-if (function (lambda (a) (equal (strcase (cadr a)) (strcase UserInput)))) proplst)
Hope this helps,
Henrique
Message 16 of 19
BeKirra
Try
Hope this helps,
Henrique
Brilliant! I have never thought this:
(strcase (cadr a))
Just another thought after learning from your code:
What if I want to get the value from an attribute in a block?
It would be much appreciated if you can give more helps.
Here is a case.
For example, there are couple of attributes in an existing block "Block_ABC":
Attribute_1: Tag = "Tag_1", Prompt (Value) = "TagValue_1"
Attribute_2: Tag = "Tag_2", Prompt (Value) = "TagValue_2"
Attribute_3: Tag = "Tag_3", Prompt (Value) = "TagValue_3"
etc
How to
1) get the value from "Attribute_3", then
2) allow user change the value if needed?
(Assuming all the names of attribute tag are known.)
X² + Y² = C²
Message 17 of 19
hmsilva
@BeKirra wrote:
Try
Hope this helps,
Henrique
(strcase (cadr a))
Here is a case.
etc
How to
To get a list with TAGS and VALUES
;; enm = VLA-OBJECT or ENAME
;; (get_atts enm)
(defun get_atts (enm / att obj)
  (if (or (and (eq (type enm) 'ENAME)
               (setq obj (vlax-ename->vla-object enm))
               (eq (vla-get-hasattributes obj) :vlax-true)
          (and (eq (type enm) 'VLA-OBJECT)
               (setq obj enm)
    (mapcar
      '(lambda (att)
         (cons (vla-get-TagString att) (vla-get-TextString att))
      (vlax-invoke obj "GetAttributes")
to change specific TAG value
;; obj = VLA-OBJECT or ENAME
;; tag = the tag as a STRING
;; newstr = the new VALUE as a string
;; usage
;; (ed_att obj "tagname" "NewValue")
(defun ed_att (obj tag newstr / atts)
  (cond ((and (eq (type tag) 'STR)
              (eq (type newstr) 'STR)
              (or (eq (type obj) 'ENAME)
                  (eq (type obj) 'VLA-OBJECT)
         (if (eq (type obj) 'ENAME)
           (setq obj (vlax-ename->vla-object obj))
         (if (and (eq (vla-get-objectname obj) "AcDbBlockReference")
                  (vlax-write-enabled-p obj)
                  (setq atts (vlax-invoke obj "GetAttributes"))
           (foreach att atts
             (if (eq (vla-get-tagstring att) (strcase tag))
               (vla-put-textstring att newstr)
Hope this helps,
Henrique
Message 18 of 19
BeKirra
Sorry, I tried but no success. Here is the code to change a tag value in block:
What is wrong?
(defun c:Test (/ ss obj TagName NewValue)
(if (princ "\nSelect a block: ")
(setq ss (ssget "_:S:E" '((0 . "INSERT") (2 . "BlockName")))) ; change "BlockName" to yours
(setq obj (vlax-ename->vla-object (ssname ss 0)))
(setq TagName "TAG") ; "TAG" is a tag name in your block.
(setq NewValue "123") ; to set new value "123" to "TAG".
           (foreach att atts
(ed_att (vla-get-effectivename obj) TagName NewValue)
(princ)
X² + Y² = C²
Message 19 of 19
hmsilva
Hi
try
(vl-load-com)
(defun c:Test (/ ed_att ss obj TagName NewValue)
                (foreach att atts
   (if (and (princ "\nSelect a block: ")
      (progn
         ;; ed_att function, needs a VLA-OBJECT or an ENAME as obj argument...
         (ed_att obj TagName NewValue)
   (princ)
Hope this helps,
Henrique
