Drainage Program
Drainage Program
_Tharwat
Advisor Advisor
Message 1 of 9
Drainage Program
_Tharwat
My Dynamic Drainage program release: 5.1.2 that uses Imperial scale along with 3 scales in metric system, you can download the program from Autodesk Apps. Store or from my website as follows:
https://autolispprograms.wordpress.com/one/drainage-pipe/
DP500 Create-Layer Dialog.PNGDP500- Insert Block Dialog.PNGDP500-Imperial Main Dialog.PNGDP500-Main Dialog with 45 Insersecting-option.PNGDP500-Main Dialog with 90 Insersecting-option.PNGDP500-Metric Main Dialog.PNGDP500-Scale Dialog.PNG
Replies (8)
Message 2 of 9
john.uhden
What kind of drainage pipe are you designing?
Here in New Jersey, junctions and changes in direction require a manhole or inlet structure, not a TY.
John F. Uhden
Message 3 of 9
_Tharwat
Hello John,
Yes the manhole should be used in lieu of TY in the external network and in basement floors but in the internal connections the clean out and TY should be used based on the situation.
The program designed to work with uPVC Terrain and Cosmoplast pipes and fittings and this is the most general types used over the world although, generally lots of users use this program for the Drainage system regardless of the forms of the pipes & fittings but with concentration on the routes and right connections.
Message 4 of 9
Sea-Haven
The definition here of what is "drainage" may help, I thinks it more options 1 and 2 below, I am sure Tharwat will confirm.
Household / Building internal drainage systems upvc mainly
Household / Building internal Sewer drainage systems upvc mainly
Storm water Buildings
Storm water streets
Here in Aus may sound silly but there is 90 and 100mm pipes can extras or others be added ?
Message 5 of 9
_Tharwat
Yes, your definition is correct.
But the two sizes you mentioned are not existed at least in the Middle east but there is 80 mm size instead of the 75 mm but in imperial size both are the same 3".
Message 6 of 9
hak_vz
Across central Europe standard nominal diameters for PVC-U pipes and fittings for drainage systems inside buildings are 32, 40, 50, 63, 75, 80, 90 ,100, 110, 125 and 160 mm.
Miljenko Hatlak
Message 7 of 9
_Tharwat
Thank you for the info.
Message 8 of 9
diagodose2009
Command:
Command: Specify opposite corner:
Command: dp
Error => bad argument type: stringp nil
This program was written by Tharwat Al Shoufi
Command:
Message 9 of 9
_Tharwat
You need to locate the drawing into your AutoCAD search path like ( Support folder ) then start with any drawing and not in the same drawing that is attached with the program.
