Block Rename to Attribute Tag Value
NAZEEB.HAMZA
Message 1 of 15
NAZEEB.HAMZA
Hi All,
I am trying to rename my blocks with the Attribute tag value.
In the included example drawing I have 2 different Blocks (Style-M) & (Style-L) with multiple copies of each.
And each copies have its unique Attributes and I want to rename each copies of the block using the Attribute values.
For e.g. Style-M blocks will need be renamed using the attributes to 2000, 2001, 2002 ...
I have been searching the forum and the closest I could find is the below.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/block-rename-to-attribute-text-value...
The LISP as it is doesn't work for my requirement, but I am hopeful that the experts here can provide a solution.
Thanks!
Nazeeb H
Replies (14)
Message 2 of 15
pbejse
Untested... copied from link
I see its a different , let me get my hands on a computer, hang on.
Here you go.
(Defun c:renb ( /. aDoc blocks ss i effname e)
  (setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object))
	blocks (vla-get-blocks adoc))
  	(if (setq ss (ssget "_:L" '((0 . "INSERT"))))
	  	(repeat (setq i (sslength ss))
		  	(setq e (vlax-ename->vla-object (ssname ss (setq i (1- i))))
				effname (vla-get-EffectiveName e))
		  (cond
		    (	(not (setq atval (vl-some
				      '(lambda (at)
					 (if (= (vla-get-tagstring at) "PK1") (vla-get-textstring at)))
			  	(vlax-invoke e 'GetAttributes)))
		    ( (tblsearch "BLOCK" atval) (vlax-put e 'Name atval)
		    ( (=  effname atval)	)
		    ( T
		       (vlax-invoke e 'ConvertToAnonymousBlock)
		       (vla-put-name (vla-item blocks (Vlax-get e 'Name)) atval) )
  (princ)
HTH
Message 3 of 15
kajanthangavel
It working..... 😀
Message 4 of 15
NAZEEB.HAMZA
Awesome!!! It is working, Thanks a lot Mr. Patrick.
I also really appreciate the quick response.
Message 5 of 15
pbejse
Awesome!!! It is working, Thanks a lot.
Also I really appreciate the quick solution!
Good to hear that. You are welcome  🙂
- One is glad to be of service --
Nice to know it works for you too @kajanthangavel
Message 6 of 15
Hi!
Thanks for the code.
Is it possible to change the code so it makes a new block but only whit the content of the specified layer? I have a block that contains two layers and I need content of only one layer.
Thank you!
Denis
Message 7 of 15
pbejse
That's an interesting twist to the original intent of the code. I supposed it can be done. How would the user specify the layer ? and what will be the eventual name of the block? will it still be from an attribute value?
Message 8 of 15
thanks for answer
it could be specified in the code that the content of the layer named LAYER1 should create the new named block.
I didn't say at the first post...content of the second layer should move outside the block, not to be deleted.
Yes, the name will still be from an attribute value.
tnx
d
Message 9 of 15
pbejse
-move outside the block, -
On every instance of the block?
A sample drawing would explain much better than how the way you were describing the intent.
Message 10 of 15
Sorry for not being clear...here is a sample drawing
content of layer2 could be in the old block if that's easier to do...
Message 11 of 15
pbejse
But what of the value of the attributes? Are you wanting to retain the value and not leave it as a broken link?
Message 12 of 15
If it's any problem to retain value it can be a broken link.
Message 13 of 15
pbejse
I had to delete the "K_NP_125_65_140" block that was there on the sample drawing , as the insertion point is way off.
Here's how the code works
The list shown on the code is key.
(setq BnameLayer '(("POLICA" "POLICA" "LAYER1")))
  • The first item of the list is the Block name
  • Second item is the TAG name as the source for the new name
  • Third item is the layer name to be retained on the renamed block, the rest will be left "outside"
Command: REBeL
Select objects: Specify opposite corner: 12 found
Select objects:
Block reference renamed to: K_NP_125_65_140
Block reference renamed to: K_NP_125_35_140
Block reference renamed to: K_NP_100_45_140
Block reference renamed to: K_NP_90_35_140
HTH
Refer to attached files [ Rename Explode By Layer.dwg | Rename Explode By Layer.lsp ]
Message 14 of 15
Thank you very much, it is working perfectly!
Regards!
Denis
Message 15 of 15
pbejse
Regards!
Denis
Glad i could help 🙂
