Running Autocad Civil 3d in silent mode
I am running AutoCad Civil 3d in silent mode, by using accoreconsole.exe /i "[drawing file].dwg" /s [Script File].scr" in command prompt. The issue is the command does not seem to enter into the dll. I have a write to console text message and a text file creation command in the dll file , but after executing in cmd, the text file is not created and the message does not appear as well. However there are no errors in cmd (attached image).
Is there a solution? Thanks in advance.
Sea-Haven
Try without the write to console I know 1 rule is no user interaction.
@Sea-Haven
Thank you for the response. Could you be more elaborate? I am not able to understand your message clearly.
Sea-Haven
Your quote "I have a write to console text message"
I can understand why the message is not displayed due to no user interaction. But the sample text file is not created.
I am creating a sample text file in a local directory to know the success of the command.
The custom command "CorridorToSld" is not getting invoked. The script file calls the custom dll.
Any reason for this?
Sea-Haven
Sorry beyond my expertise make a much simpler .dll and test. Like how many objects in dwg write to file.
