Doubts for vl-close
Doubts for vl-close
carlos_m_gil_p
Doubts for vl-close
carlos_m_gil_p
Hello boys. How are you.
Can someone tell me, what is the way to close the current drawing with vl-close.
Thank you.
AutoCAD 2026
Visual Studio Code 1.99.3
AutoCAD AutoLISP Extension 1.6.3
Windows 10 (64 bits)
roland.r71
I'll presume you mean: vlA-close... (as vl-close doesn't exist)
I'm anything but an expert when it comes to ActiveX, but i'm an expert with google 😛
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-ActiveX/files...
carlos_m_gil_p
Hello how are you.
Thank you for the correction. You're right, it's vla-close.
But I do not get where to edit the post.
Before asking, I had already searched in google.
But I can not solve for vla-close when I need to close the current drawing.
Thank you.
AutoCAD 2026
roland.r71
"You cannot close a drawing from inside an event handler for that drawing."
This line tells me you can't. (& acad tells me the drawing is busy, when i try)
I did find a different aproach (still using VBA)
(command "._VBASTMT" "ThisDrawing.Close False")
Which works for me.
carlos_m_gil_p
Hi, I saw that, but I do not have that module installed.
And it would be more work, to have to install it.
AutoCAD 2026
roland.r71
so... why not use (command "_.close") ?
(command "_.close" (if (/= (getvar "dbmod") 0) "_Yes"))
Will do the same.
note: IF the drawing changed it will answer _Yes to the question: "Realy discard changes?"
carlos_m_gil_p
Hi.
I currently have it like that. (command "_.close")
The purpose was to learn how to use vla-close for an active drawing.
Thank you.
AutoCAD 2026
