Extract properties from the current drawing with getpropertyvalue
carlos_m_gil_p
carlos_m_gil_p
Hello how are you.
You could tell me how to extract properties from the current drawing with getpropertyvalue.
Thank you
AutoCAD 2026
Visual Studio Code 1.99.3
AutoCAD AutoLISP Extension 1.6.3
Windows 10 (64 bits)
Try this:
(command "_circle" "2,2" 2)
nil
(getpropertyvalue (entlast) "radius")
2.0
Júnior Nogueira.
Por favor,  Aceitar como Solução se meu post te ajudar.
Please Accept as Solution if my post helps you.
carlos_m_gil_p
Sorry, I wrote the function wrong.
I want Extract properties from the current drawing with dumpAllProperties
Currently I use it like this (dumpAllProperties (car (entsel)) 1)
But not of any object, I want is of the current drawing.
Sorry, my mistake.
AutoCAD 2026
doaiena
If you want to get information from the drawing itself, you should use the document object.
(vl-load-com)
(vlax-dump-object (vla-get-activedocument (vlax-get-acad-object)))
carlos_m_gil_p
Hi, doaiena, thanks for the help.
I wanted the function dumpAllProperties, but it works for me. Thank you.
AutoCAD 2026
