How to combine 3 selections into one?
Hello.
This routine needs to many clicks. How to combine these 3 IF's into 1?
(DEFUN C:HAll ( / multiple hatch edit )
 (if (and (princ "\nSelect HatchPatterns to change their type and HatchScale")
	  (setq stone (ssget "_:L" '((0 . "HATCH") (2 . "ANSI31,_O") (41 . 1))))
   (progn
     (initcommandversion)
	 (COMMAND "_-HATCHEDIT" stone "" "_Properties" "" "0.5" "")
	(setq skimcoat (ssget "_:L" '((0 . "HATCH") (2 . "AR-SAND") (41 . 0.15))))
   (progn
	 (COMMAND "_-HATCHEDIT" skimcoat "" "_Properties" "" "0.07" "")
	  (setq gwb (ssget "_:L" '((0 . "HATCH") (2 . "AR-SAND") (41 . 0.3))))
   (progn
	 (COMMAND "_-HATCHEDIT" gwb "" "_Properties" "" "0.15" "")
  (princ);
doaiena
I haven't tested the code, but it should work.
(defun c:hall ( / ss ssLen ctr ent ed name scale)
(prompt "\nSelect HatchPatterns to change their type and HatchScale")
(if (setq ss (ssget "_:L" '((0 . "HATCH") (-4 . "<OR") (2 . "ANSI31,_O") (2 . "AR-SAND") (-4 . "OR>"))))
(progn
(setq ssLen (sslength ss)
      ctr 0)
(repeat ssLen
(setq ent (ssname ss ctr)
      ed (entget ent)
      name (cdr (assoc 2 ed))
      scale(cdr (assoc 41 ed))
(cond
((and (equal name "ANSI31,_O") (equal scale 1))
(command "_-HATCHEDIT" ent "" "_Properties" "" "0.5" "")
((and (equal name "AR-SAND") (equal scale 0.15))
(command "_-HATCHEDIT" ent "" "_Properties" "" "0.07" "")
((and (equal name "AR-SAND") (equal scale 0.3))
(COMMAND "_-HATCHEDIT" ent "" "_Properties" "" "0.15" "")
);cond
(setq ctr (1+ ctr))
);repeat
));if ss
(princ)
);defun
john.uhden
How about if you select all the hatches, then one-by-one get their entity data and run each through a list of conditions for the varying codes 2 and 41?
John F. Uhden
doaiena
Is this what you meant @john.uhden?
(defun c:hall ( / ss ssLen ctr ctr1 ent ed name scale nameLst scaleLst propLst)
(if (setq ss (ssget "_:L" '((0 . "HATCH"))))
(progn
      ctr 0
      nameLst  (list "ANSI31,_O" "AR-SAND" "AR-SAND")
      scaleLst (list 1           0.15      0.3)
      propLst  (list 0.5         0.07      0.15)
(repeat ssLen
      ed (entget ent)
      scale (cdr (assoc 41 ed))
(setq ctr1 0)
(repeat (length nameLst)
(if (and (equal name (nth ctr1 nameLst)) (equal scale (nth ctr1 scaleLst)))
(progn
(command "_-HATCHEDIT" ent "" "_Properties" "" (rtos (nth ctr1 propLst)) "")
(setq ctr1 (1+ ctr1))
);repeat
(setq ctr (1+ ctr))
);repeat
));if ss
(princ)
);defun
john.uhden
Perhaps better, but I think @doaiena got it best.  He used (cond ...)
John F. Uhden
ВeekeeCZ
I would say that "ANSI31,_0" are two patterns.
doaiena
Now that you brought it to my attention, i think you are right @ВeekeeCZ. Maybe this is a better solution?
(defun c:hall ( / ss ssLen ctr ctr1 ent ed name scale hatchLst)
(progn
      ctr 0
      hatchLst (list (list "ANSI31" 1 0.5)
		     (list "AR-SAND" 0.15 0.07)
		     (list "AR-SAND" 0.3 0.15)
		     (list "_O" 1 0.5)
(repeat ssLen
      ed (entget ent)
(foreach n hatchLst
(if (and (equal name (car n)) (equal scale (cadr n)))
(progn
(command "_-HATCHEDIT" ent "" "_Properties" "" (rtos (caddr n)) "")
);foreach
(setq ctr (1+ ctr))
);repeat
));if ss
(princ)
);defun
