divide with block
divide with block
shefipmoosa
Message 1 of 10
divide with block
shefipmoosa
iam using below mentioned code for divide option.but iam getting the point style only. I need to place "selected block" instead of point style.
(defun c:div ()
  (setq val (getint " no of POINTS"))
  (setq val (* 2 val))
  (command "divide" pause val)
  (setq ss (ssget "p"))
  (setq co 1)
  (setq len (sslength ss))
  (repeat len
    (setq en (ssname ss co))
    (setq det (entget en))
    (entdel en)
    (setq co (+ co 2))
Replies (9)
Message 2 of 10
3wood
There is a Block option in DIVIDE command. No need lisp.
Message 3 of 10
dlanorh
(defun c:div ()
  (setq co 1)
  (repeat len
    (entdel en)
    (setq co (+ co 2))
You are not telling it to divide with a block
replace
with
(command "divide" pause "_B" "xxx" ("_Y" or "_N") val)
replace "xxx" with the name of the block you want to divide the line with
delete "_Y" or "_N" depending on whether you want to align the blocks "_Y" or not "_N"
I'm not sure what the rest of you code is trying to do
I am not one of the robots you're looking for
Message 4 of 10
shefipmoosa
autocad divide option are different,This code iam using for placing no.of lights.( if 3 lights lighting placement methord is starting point point to x, next two point are 2x ,and 3rd to end x ) this code already customized as per this requirement. but I gave number of point its coming to point style, I need to add selected block / block name instead of point style.
Message 5 of 10
Kent1Cooper
@shefipmoosa wrote:
.... if 3 lights lighting placement methord is starting point point to x, next two point are 2x ,and 3rd to end x .....
You can use the DIV+ command in DivideMeasurePlus.lsp, available >here<.  One of its many enhancements over ordinary DIVIDE is that it has an option to place the markers [with Blocks as one of the options] at the midpoints  of the divided segments, rather than at the dividing points.  You would use the Block option and use that midpoints option with 3 as the number of divisions.
Kent Cooper, AIA
Message 6 of 10
Sea-Haven
Sounds like a custom divide take length divide by a spacing, then start 1st block at a distance from start end is same distance. Plenty of code examples provide the required spacing.
Message 7 of 10
Kent1Cooper
@Sea-Haven wrote:
... take length divide by a spacing, then start 1st block at a distance from start end is same distance. ....
If I understood the OP's description correctly, this is what they're really looking for:
DIV+ will do that.  Here's the command sequence that did the above [dark blue are typed-in entries]:
Command: DIV+
Divide with Points/Blocks/Lines/Selection ? <P>: S
For Selection set with which to Divide,
Select objects: {select the Circle, which can be anywhere} 1 found
Select objects: {Enter to complete selection}
Base point in relation to Selection: CEN of {pick on the Circle to get its center}
Selection rotation, or Aligned with path or Relative angle to path [angle/A/R] <A>: {enter to accept default -- doesn't matter in this case}
Enter number of Segments, or M for Maximum spacing <M>: 3
Place Selection at division points (Standard) or at Midpoints of divisions [S/M]? <S>: M
Select object to Divide: {select the Line}
Select object to Divide: {enter to end command}
Kent Cooper, AIA
Message 8 of 10
Kent1Cooper
... and note that in line with the original request, DIV+ offers a Blocks option, also, and if that is chosen, the rotation [which doesn't matter for a Circle] has several options [more than regular Divide offers].
Kent Cooper, AIA
Message 9 of 10
Sea-Haven
Your right just need the poster now to respond its nice to know if it matched their needs.
Message 10 of 10
shefipmoosa
GREAT SIR, THANKS
