Visual LISP, AutoLISP and General Customization
divide with block
9 REPLIES 9
Message 1 of 10
shefipmoosa
1628 Views, 9 Replies
divide with block
iam using below mentioned code for divide option.but iam getting the point style only. I need to place "selected block" instead of point style.
(defun c:div ()
  (setq val (getint " no of POINTS"))
  (setq val (* 2 val))
  (command "divide" pause val)
  (setq ss (ssget "p"))
  (setq co 1)
  (setq len (sslength ss))
  (repeat len
    (setq en (ssname ss co))
    (setq det (entget en))
    (entdel en)
    (setq co (+ co 2))
9 REPLIES 9
Message 2 of 10
3wood
in reply to: shefipmoosa
There is a Block option in DIVIDE command. No need lisp.
Message 3 of 10
dlanorh
(defun c:div ()
  (setq co 1)
  (repeat len
    (entdel en)
    (setq co (+ co 2))
You are not telling it to divide with a block
replace
with
(command "divide" pause "_B" "xxx" ("_Y" or "_N") val)
replace "xxx" with the name of the block you want to divide the line with
delete "_Y" or "_N" depending on whether you want to align the blocks "_Y" or not "_N"
I'm not sure what the rest of you code is trying to do
I am not one of the robots you're looking for
Message 4 of 10
shefipmoosa
in reply to: 3wood
autocad divide option are different,This code iam using for placing no.of lights.( if 3 lights lighting placement methord is starting point point to x, next two point are 2x ,and 3rd to end x ) this code already customized as per this requirement. but I gave number of point its coming to point style, I need to add selected block / block name instead of point style.
Message 5 of 10
Kent1Cooper
@shefipmoosa wrote:
.... if 3 lights lighting placement methord is starting point point to x, next two point are 2x ,and 3rd to end x .....
You can use the DIV+ command in DivideMeasurePlus.lsp, available >here<.  One of its many enhancements over ordinary DIVIDE is that it has an option to place the markers [with Blocks as one of the options] at the midpoints  of the divided segments, rather than at the dividing points.  You would use the Block option and use that midpoints option with 3 as the number of divisions.
Kent Cooper, AIA
Message 6 of 10
Sea-Haven
Sounds like a custom divide take length divide by a spacing, then start 1st block at a distance from start end is same distance. Plenty of code examples provide the required spacing.
Message 7 of 10
Kent1Cooper
in reply to: Sea-Haven
@Sea-Haven wrote:
... take length divide by a spacing, then start 1st block at a distance from start end is same distance. ....
If I understood the OP's description correctly, this is what they're really looking for:
DIV+ will do that.  Here's the command sequence that did the above [dark blue are typed-in entries]:
Command: DIV+
Divide with Points/Blocks/Lines/Selection ? <P>: S
For Selection set with which to Divide,
Select objects: {select the Circle, which can be anywhere} 1 found
Select objects: {Enter to complete selection}
Base point in relation to Selection: CEN of {pick on the Circle to get its center}
Selection rotation, or Aligned with path or Relative angle to path [angle/A/R] <A>: {enter to accept default -- doesn't matter in this case}
Enter number of Segments, or M for Maximum spacing <M>: 3
Place Selection at division points (Standard) or at Midpoints of divisions [S/M]? <S>: M
Select object to Divide: {select the Line}
Select object to Divide: {enter to end command}
Kent Cooper, AIA
Message 8 of 10
Kent1Cooper
in reply to: Kent1Cooper
... and note that in line with the original request, DIV+ offers a Blocks option, also, and if that is chosen, the rotation [which doesn't matter for a Circle] has several options [more than regular Divide offers].
Kent Cooper, AIA
Message 9 of 10
Sea-Haven
Your right just need the poster now to respond its nice to know if it matched their needs.
Message 10 of 10
shefipmoosa
GREAT SIR, THANKS
AutoCAD Inside the Factory
