Distance and length entities polyline
tuanvmvpn2012
Message 1 of 12
tuanvmvpn2012
Hi All.
I'm beginner AutoLISP, now I want to measure distance and give length total entities polylines by LISP code, Is there any one help me to resolves it. That such as Drawing attached file
Many thanks.
Replies (11)
Message 2 of 12
devitg
Despite you can use a LISP , also you can use the DATAEXTRACTION command
Message 3 of 12
paullimapa
you can find many things on-line by just googling:
TotalLength | AutoCAD | Autodesk App Store
Paul Li
IT Specialist
@The Office
Message 4 of 12
Sea-Haven
Always include "AUTOCAD" when googling.
"Get total length of lines Autocad"
Message 5 of 12
-didier-
Bonjour @tuanvmvpn2012
If I understood the request correctly according to the drawing provided.
I think it’s something of the kind you expect.
Did I understand correctly?
If yes I will give you the code, if not I ask for further explanation.
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 6 of 12
tuanvmvpn2012
Thanks all replied;
I have alot of cross section to creat, so I mean want to creat cross section from files (txt, csv....) or contour, I want to note the distance of segments one by one and total length in other row the same in my drawing.
If you have code to do that, pls help me.
Thanks you in advance
Message 7 of 12
ВeekeeCZ
Are you really learning or is it just an empty phrase?
If so, where is some attempt of yours? Where did you get stuck and need to advise some direction?
BTW with QDIM is fairly quick and easy to achieve such a result, see THIS
Message 8 of 12
-didier-
I don’t understand about you talking about CSV file.
Is that a new question?
I also understand that it is not the distances that must be written,
but the differences between abscises, we agree?
Amicalement
DA
Message 9 of 12
-didier-
You seem to have sent two messages to ask your question.
One is an old message from 2002 that you relaunched.
It wasn’t a good idea.
You didn’t talk here about putting the data in an external file.
However, it seems that you have been answered, and in this case we thank you for marking the subject as resolved.
I’m talking about this message:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/get-polyline-length/m-p/11445325#M43...
Amicalement
DA
Message 10 of 12
Sea-Haven
The post heading appears to be totally misleading.
"So I mean want to create cross section from files (txt, csv....) or contour."
Answer is CIV3D or other software, eg  Civil Site Design.
Yeah there is some other stuff out there, start googling.
Message 11 of 12
tuanvmvpn2012
Dear Sir;
Thanks for your replied
I'm sorry for replying to your message late. The video you gave is my purpose. I wish to your support and guidance.
I hope, I can have your code,
Thank you in advance.
Message 12 of 12
calderg1000
Regards @tuanvmvpn2012
Try this code, although maybe a little late...
(defun c:DtPerf (/ pt_list s)
  (setq s (car (entsel "\nSelect Profile (Lwpolyline)")))
  (dtS s)
(defun dtS (s / lp ht p n d pm x tx)
  (setq
    lp (mapcar
         'cdr
         (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget s))
    ht 0.3
    p  (getpoint "Pick Point: ")
    n  0
    da 0
  (repeat (1- (length lp))
    (setq dp (distance (nth (1+ n) lp) (nth n lp))
          da (+ da (distance (nth (1+ n) lp) (nth n lp)))
          pm (mapcar '/ (mapcar '+ (nth (1+ n) lp) (nth n lp)) '(2. 2.))
    (setq ltx (list (rtos dp 2 2) (strcat "\n\n" (rtos da 2 2))))
    (foreach x ltx
      (setq tx (entmakex (list '(0 . "text")
                               (cons 100 "AcDbEntity")
                               (cons 100 "AcDbText")
                               (cons 10 (list (car pm) (cadr p)))
                               (cons 1 x)
                               (cons 40 ht)
                               (cons 72 1)
                               (cons 11 (list (car pm) (cadr p)))
                               (cons 73 1)
    (setq n (1+ n))
  (princ)
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
