Fas file with special format
a_dankoob
Observer Observer
a_dankoob
Observer
Observer
Hello.
Can you figure out how this fas file is compiled.
Its structure is different from the Visual Lisp compiler defaults.
I don't know how it is compiled with this structure.
I think each function is placed in a fas block
In a Visual Lisp output fas file we have this structure.
FAS4-FILE ; Do not change it!
;fas4 crunch
;$;A9/6/21
If we are faced with this structure in the fas file that I sent.
FAS4-FILE 1 0
10 0
FAS4-FILE ; SYZ2019R
;fas4 crunch
;$;A9/6/22
FAS4-FILE ;
2
$;A0/94/91
FAS4-FILE ;
2
$;A0/94/91
Why.
How is the fas file created with this structure?
thank you.
komondormrex
(vlisp-compile 'mode filename [output-filename])
mode
Type: Symbol
The compiler mode, which can be one of the following symbols:
st Standard build mode - Produces the smallest output file and is suitable for programs consisting of a single file.
lsm Optimize and link indirectly - Optimizes the compiled files, but does not create direct references to the compiled functions in the compiled code.
lsa Optimize and link directly - Optimizes the compiled files and creates direct references to the compiled function in the compiled code, instead of to the function symbol.
three modes - three structures, i suppose
