Here is my revision...
(defun c:dimcurve ( / _line _arrow a b cm el en p q pt )
(if (tblsearch "LAYER" "Dims")
(setvar "CLAYER" "Dims")
(vl-cmdf "_.-layer" "_m" "Dims" "")
) ;;; mod. by M.R.
(defun _line ( a b )
(entmake (list '(0 . "LINE") (cons 10 a) (cons 11 b)))
(defun _arrow ( a b )
(entmake
(list
'(0 . "LWPOLYLINE")
'(100 . "AcDbEntity")
'(100 . "AcDbPolyline")
'(90 . 2)
'(70 . 0)
(cons 10 a)
'(40 . 0.0)
(cons 41 (/ (distance a b) 3.0))
(cons 10 b)
(while
(progn (setvar 'errno 0) (setq en (car (entsel)))
(cond
( (= 7 (getvar 'errno))
(princ "\nMissed, try again.")
( (eq 'ename (type en))
(if (not (wcmatch (cdr (assoc 0 (entget en))) "ARC,CIRCLE,ELLIPSE,LINE,LWPOLYLINE,SPLINE"))
(princ "\nInvalid Object Selected.")
(if
(and en
(setq pt
(getpoint "\nSpecify Dimension Offset: "
(trans
(vlax-curve-getpointatparam en
(/ (+ (vlax-curve-getendparam en) (vlax-curve-getstartparam en)) 2.0)
0 1
(progn
(setq el (entlast)
cm (getvar 'cmdecho)
(setvar 'cmdecho 0)
(command "_.offset" "_T" en "_non" pt "")
(setvar 'cmdecho cm)
(if (equal el (setq el (entlast)))
(princ "\nUnable to Create Dimension Line.")
(progn
(entupd (cdr (assoc -1 (entmod (subst (cons 8 "Dims") (assoc 8 (entget el)) (entget el)))))) ;;; mod. by M.R.
(setq a (vlax-curve-getstartpoint en)
b (vlax-curve-getstartpoint el)
(_line
(polar a (angle a b) (/ (distance a b) 6.0))
(polar b (angle a b) (/ (distance a b) 6.0))
(setq a (vlax-curve-getendpoint en)
b (vlax-curve-getendpoint el)
(_line
(_arrow
(polar (vlax-curve-getstartpoint el)
(angle '(0.0 0.0 0.0) (vlax-curve-getfirstderiv el (vlax-curve-getstartparam el)))
(getvar 'dimasz)
(_arrow
(polar (vlax-curve-getendpoint el)
(+ pi (angle '(0.0 0.0 0.0) (vlax-curve-getfirstderiv el (vlax-curve-getendparam el))))
(getvar 'dimasz)
(setq a (vlax-curve-getpointatdist el (/ (vlax-curve-getdistatparam el (vlax-curve-getendparam el)) 2.0))
b (angle '(0.0 0.0) (vlax-curve-getfirstderiv el (vlax-curve-getparamatpoint el a)))
p (polar a (+ b (/ pi 2.0)) (* 1.25 (getvar 'dimtxt))) ;;; mod. by M.R.
q (polar a (- b (/ pi 2.0)) (* 1.25 (getvar 'dimtxt))) ;;; mod. by M.R.
(if (< (distance p (vlax-curve-getclosestpointto en p))
(distance q (vlax-curve-getclosestpointto en q))
(setq p q)
;;; start mods. by M.R.
(entmake
(list
'(000 . "TEXT")
(cons 7 (getvar "textstyle"))
(cons 10 (mapcar '+ p (mapcar '- p a)))
(cons 11 (mapcar '+ p (mapcar '- p a)))
(cons 40 (getvar 'dimtxt))
(cons 01 (rtos (vlax-curve-getdistatparam en (vlax-curve-getendparam en)) 2 1))
(cons 50 (LM:readable b))
'(072 . 1)
'(073 . 2)
(entmake
(list
'(000 . "TEXT")
(cons 10 p)
(cons 11 p)
(cons 01 (strcat "[" (rtos (* (vlax-curve-getdistatparam en (vlax-curve-getendparam en)) 25.4) 2 0) "mm]"))
'(072 . 1)
'(073 . 2)
;;; end mods. by M.R.
(princ)
(defun LM:readable ( a )
( (lambda ( a )
(if (< a 0.0)
(LM:readable a)
(if (and (< (* pi 0.5) a) (<= a (* pi 1.5)))
(LM:readable (+ a pi))
a
(rem (+ a pi pi) (+ pi pi))
(vl-load-com) (princ)
HTH. M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
