Take Part From Block or XREF
I know about NCOPY to take object copy from Block or Xref, also l know about CLIP to show only part of Block/Xref,  and I found lisp to cut objects with more options, one of them (Break objects touching selected objects), I need to use this option to cut or trim part from block/Xref.
@ВeekeeCZ  Dear mr.Beekeeper, please  help me in mentioned issue, if you can?.
marko_ribar
Use command REFEDIT, select block/xref, choose all subentities, do trim operation, type REFCLOSE and do click on SAVE changes... That's all...
HTH.
Marko Ribar, d.i.a. (graduated engineer of architecture)
