Find coordinates of text in box.
davidlanesmith673
davidlanesmith673
In my AutoLISP code I am creating a selection set with the text and the box around it shown below. I am wondering if there is a way to determine the coordinates of the text from the selection set?
CodeDing
@davidlanesmith673 ,
Do you know how to loop through a Selection Set to get the entity names? This sounds like what you are wanting because once you have the entity name of the TEXT object, you can get what you want from it:
(defun c:TEST ( / ss cnt e)
  (if (setq ss (ssget '((0 . "LWPOLYLINE,TEXT"))))
    (progn
      (repeat (setq cnt (sslength ss))
        (setq e (ssname ss (setq cnt (1- cnt))))
        (prompt (strcat "\nHere is the " (cdr (assoc 0 (entget e))) " entity!"))
      );repeat
    );progn
  ;else
    (prompt "\nNo LWPolylines or Text were selected.")
  );if
  (princ)
);defun
Does that help?
Best,
~DD
ronjonp
Look into the TEXTBOX function.
davidlanesmith673
I think so, how do you know when the entity name is for the text object, and not for the polyline?
CodeDing
It would go something like this:
        (if (eq "TEXT" (cdr (assoc 0 (entget e))))
          (prompt "\nHere is a Text entity!")
        );if
      );repeat
Best,
~DD
davidlanesmith673
Yah I think I understand entities a bit better now, I figured it out now, thank you for your help!!
Sea-Haven
 Another way is get selection of plines then use ssget "WP" lst '((0 . "TEXT")) so it will look inside for text can be irregular shapes as well. A common use is "room number" and "area". Using "Lwpolylines,TEXT" can find text outside of a box.
