Diesel Expression to Display Part of File Path in a Field
neabailey
neabailey
Hello, Is there a way to have a field display only a portion of the file path? A saw a similar post but referring to file name only, here: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/diesel-expression-to-display-part-of...
I'm looking for something similar but with file path. The first part of the path that I don't want to show looks like this : X: \XXXXXX\## XXX\XXXXXXX\
everything after that I want to show, including the file name.
Is it possible to write something that states that everything before the 4th backslash should be ignored and everything else is shown?
neabailey
@doni49 I'll tag you since you helped with a similar situation
Sea-Haven
Maybe something like this using getfile
; thanks to Lee-mac for this defun
(defun csv->lst ( str / pos )
(if (setq pos (vl-string-position 42 str))
    (cons (substr str 1 pos) (csv->lst (substr str (+ pos 2))))
    (list str)
(setq str "D:\\Bigal\\stuff\\20090909-photo\\P1010001.JPG")
(while (VL-STRING-POSITION 92 str)
(setq str (vl-string-subst "*" "\\" str 1))
(setq ans (csv->lst  str ))
 ("D:" "Bigal" "stuff" "20090909-photo" "P1010001.JPG")
("X:" "XXXXXX" "## XXX" "XXXXXXX" "")
Just join back what you want as a string.
john.uhden
@neabailey
At first I misunderstood your intent, so we have @shrinkstr1.
Then I read again, so we have @shrinkstr2.
(defun @shrinkstr1 (str / pos i str1 str2)
  (vl-load-com)
  (setq i 0 pos 0)
  (while (< i 4)
    (if (setq pos (vl-string-search "\\" str (1+ pos)))
      (setq i (1+ i))
      (setq i 5)
  (setq str1 (substr str 1 (setq i (1+ pos))))
  (while (setq i (vl-string-search "\\" str (1+ i)))
    (setq pos i)
  (setq str2 (substr str (+ pos 2)))
  (strcat str1 "..." str2)
(defun @shrinkstr2 (str / pos i str1 str2)
  (vl-load-com)
  (setq i 0 pos 0)
  (while (< i 4)
      (setq i (1+ i))
      (setq i 5)
  (substr str (1+ pos))
John F. Uhden
