Diesel Expression that reads the Layout tab?!
FeeopEngr
FeeopEngr
I need a little help as I know very little about diesel, other than it can do what i want.
Starting with the string below, I need 2 expressions.
$(upper,$(getvar,ctab),$(-,$(strlen,$(getvar,ctab)),1),5)
One that gives me the last 5 characters of CTAB, which I think this one will and
One which gives me the first 3 characters of CTAB
My Sheet Tabs will all look like this "A-A S2.01" no quotes and a space between the 2 texts.
Thanks for the help
Feeop
hmsilva
Hi jshorttiller,
to get the last 5 characters of CTAB (in uppercase?)
$(upper,$(substr,$(getvar,ctab),$(-,$(strlen,$(getvar,ctab)​),5),5))
to get the first 3 characters of CTAB (in uppercase?)
$(upper,$(substr,$(getvar,ctab),1,3))
Hope this helps,
Henrique
FeeopEngr
Thanks HMSILVA
Almost perfect.
For the expression to get the last 5 characters, is it possible to strip off the leading space so only 4 characters show up if the tab looks like S2.0 instead of S2.01
Feeop
hmsilva
Thanks HMSILVA
Almost perfect.
You're welcome,
I think it will not be possible, DIESEL Functions, are very limited...
Using Auto/Visual LISP, It would be quite easy...
ADIT: try the the following string
$(if,$(<,$(strlen,$(getvar,ctab)),9),$(upper,$(substr,$(getvar,ctab),$(-,$(strlen,$(getvar,ctab)),3),4)),$(upper,$(substr,$(getvar,ctab),$(-,$(strlen,$(getvar,ctab)),4),5)))
Henrique
