Cannot get the correct block name from the selection set
I''m writing a script to export a grid layout (example shown in the image above) into a text file. Everything else is now working correctly, but somehow the script grabs a wrong block name (which seems like a temporary name) for one of my selection statement, screwing everything up (marked as red bold below).
  ;; For each grid, traverse through each cell to check if panel exists inside
;; Create an 2d array to mark the occupancy (of panels) for each grid
(setq n gridtot tmpset gridset) (while (> n 0) (setq n (1- n) row (caadar tmpset) y (- (cadaar tmpset) (/ *distver 2)) resultgrid nil ) (while (> row 0) (setq row (1- row) col (car (cdadar tmpset)) x (+ (caaar tmpset) (/ *disthor 2)) resultrow nil ) ;; For each cell in the row, grab all blocks inside the area to detect the ;; specified block (given as *blkname) ;; Insert 1 (true) for each occupied cell, and 0 (false) for unoccupied cell (while (> col 0) (setq col (1- col) fp (list (- x (/ *disthor 2.2)) (- y (/ *distver 2.2))) sp (list (+ x (/ *disthor 2.2)) (+ y (/ *distver 2.2))) ssp (ssget "_C" fp sp '((0 . "INSERT"))) ssl (cond (ssp (sslength ssp)) (0)) found nil ) (while (> ssl 0) (setq ssl (1- ssl) blkname (cdr (assoc 2 (entget (ssname ss ssl)))) ) (if (= blkname *blkname) (setq found T) ) ) (if found (setq resultrow (append '(1) resultrow)) (setq resultrow (append '(0) resultrow)) ) ) (setq resultgrid (cons resultrow resultgrid) y (- y *distver) ) ) )
The red block that I'm trying to detect is named as "SDA_PANEL". However, when I am debugging, the script picks it up as "*U8" (see images below).
How would I be able to resolve this?
P.S.
Is it a good practice to add a few lines at the top to save all system variables, then to load it back at the bottom?
hmsilva
Hi Edmond,
try to change
(setq ssl     (1- ssl)
to
(setq ssl     (1- ssl)
      blkname (vla-get-effectivename (vlax-ename->vla-object  (ssname ss ssl)))
and add (vl-load-com) to your code, if required.
'Is it a good practice to add a few lines at the top to save all system variables, then to load it back at the bottom?'
If in your code you are changing System Variables, yes!
Hope this helps,
Henrique
First time, I thought it had worked.
However, when I ran it back with other layouts, it seems like it's ignoring the block name that I specify.
In other words, if there were any blocks in the selection set, the "found" will automatically be set to T.
I haven't used any vl command before, so I'm not sure what to do.
hmsilva
Hi Edmond,
the test
is case sensitive, try modifying the test to
(= (strcase blkname) (strcase *blkname))
Hope this helps,
Henrique
