Diesel Expression - File name IF Equations
Oli
Oli
Hi All,
Hoping you can help me, trying to write an expression to take part of a file name to inform an attribute, but I'm having a tad of trouble, and I'm not sure if its possible?!
What I'm trying to achieve is that "VAR" in the sample file name below can be a series of pre-defined letters that equal a drawing status, and when this is change its will update the attribute in the titleblock
                  Filename = ####-###-VAR
                 ASB  = AS BUILT
                 INF = INFOMATION
So I assumed I could do something like this:   $(if, ($(eq, val1, val2)), dotrue [, dofalse])
Where:
                 Val1 = ($(substr,$(getvar,dwgname),10,3))
                 Val2 = INF
                 dotrue = Infomation
                dofalse = repeat simualr to excel IF equation. to include other variations
i have a feeling that   $(eq, val1, val2) has to be numerical?! - is there a version that works for text? that returns a 1 or 0 that would work wit with the IF equation?
Or is there a better way of doing this?
Thanks in advance!
Oli
thanks for your post - although I've already got that bit of code - what I'm trying to do is use an IF equation to convert a series of letter within the drwaing title to a full word, this would allow me to maintain file naming standard.
Paul_Gander
You are on the right track. Try this:
$(if,$(eq,$(upper,$(substr,$(getvar,dwgname),10,3)),INF),Information,$(if,$(eq,$(upper,$(substr,$(getvar,dwgname),10,3)),ASB),As built, ))
There is a limit to the number of variations you'll be able to add to this though.
ronjonp
If I'm understanding correctly you need to nest like so:
$(if,$(eq, ($(substr,$(getvar,dwgname),10,3)), INF), Information, $(if,$(eq, ($(substr,$(getvar,dwgname),10,3)), ASB), AS BUILT, XXX))
*Edit TOO SLOW 🙂
Oli
Thanks Paul,
I'd done too many brackets in my attempt - nice to know i was on the right track!
