Lisp for removing part of block name
tomwijnholt
Message 1 of 15
tomwijnholt
I'm working on a project where I'm making a library for certain profiles. I imported all the needed profiles in blocks (hundreds), but the block-name gives to much information. An example of the block-name is:
345720__2068F4F92_7C03_4052_A151_58F9C16ECC9D
What i want to have is:
345720
So everything after the first number needs to be removed. I know that the job can be done with Rename. But the drawing contains almost thousand blocks with similar names. So ideally I would like to have a Lisp Routine where I can select multiple/all blocks at once.
In the attachment you can find an example of the blocks.
Really hope some one can help me out here, any kind of input is appreciated.
Accepted solutions (4)
Replies (14)
Message 2 of 15
Moshe-A
@tomwijnholt  hi,
check this.
enjoy
moshe
; Multi Rename Block
(defun c:mrb (/ conclusion ; local function
	        iSuccsess iFailure ss exeBName newBName p)
 (defun conclusion (ctr msg)
  (cond
   ((or (not ctr) (= ctr 0))
    nil
   ( t
    (prompt (strcat "\n" (itoa ctr) " block(s) " msg))
  ); cond
 ); conclusion
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 (if (setq ss (ssget '((0 . "insert"))))
  (progn
   (setq iSuccsess 0 iFailure 0)
   (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
    (setq extBName (cdr (assoc '2 (entget ename)))) ; existing name
    (if (and
	  (setq p (vl-string-search "__" extBName))
          (null (tblsearch "block" (setq newBName (substr extBName 1 p))))
     (progn
      (command "._rename" "block" extBName newBName)
      (setq iSuccsess (1+ iSuccsess))
     ); progn
     (setq iFailure (1+ iFailure))
    ); if
   ); foreach
  ); progn
 ); if
 (conclusion iSuccsess "renamed.")
 (conclusion iFailure "fail to rename.")
 (command ".undo" "_end")
 (setvar "cmdecho" 1)
 (princ)
); c:mrb
Message 3 of 15
ВeekeeCZ
Here you go.
(defun c:BNameCut (/ ss i no nn)
  (if (and (setq ss (ssget '((0 . "INSERT"))))
	   (vl-cmdf "_.undo" "_be")
    (repeat (setq i (sslength ss))
      (if (and (setq no (cdr (assoc 2 (entget (ssname ss (setq i (1- i)))))))
	       (setq nn (itoa (atoi no)))
	       (/= nn no)
	       (/= nn "0")
	       (or (not (tblsearch "BLOCK" nn))
		   (prompt (strcat "\nRenaming '" no "' to '" nn " cancelled. Block name '" nn "' already exists.")))
	(command "_.Rename" "_Block" no nn))))
  (command "_.undo" "_end")
  (princ)
Message 4 of 15
dbhunia
You can also try this for particular type of drawings and blocks .....(Assuming all starting number of block names is separated by "__" )...
(defun c:RENB ( / doc pos BN NBN)
  (vla-StartUndoMark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
  (vlax-for blk (vla-get-blocks doc)
    (if (setq pos (vl-string-search "__" (setq BN (vla-get-name blk))))
		(if (not (tblsearch "BLOCK" (substr BN 1 pos)))
			(vla-put-name blk (setq NBN (substr BN 1 pos)))
  (vla-EndUndoMark doc)
  (princ)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 5 of 15
tomwijnholt
Perfect, exactly where I was looking for,
Thanks a lot!
Message 6 of 15
tomwijnholt
Thanks again for the previous solution.
It worked perfectly.
However, I have another challenge at the moment.
When I use your lips it only works for one block. For example, I have multiple blocks named:
345280__6A15F1CA_D91A_42A4_9EBA_69861F2C19A7
345280__8F36CF89_BD90_4183_9C30_B9DDE9B97DB9
345280__DF8347AB_1174_43A8_8AB8_DBBB5A3CA8AC
Using your lisp I will end up with:
345280
This is logical, because AutoCad can't make a new block with a name that already exist.
Is there a way to update your lisp so it overwrites the other blocks. So I will end up with the same name for multiple blocks.
There are thousands of blocks in total. So the command 'blockreplace' is to time consuming.
Hope you can help me!
Message 7 of 15
Sea-Haven
You can only have block name once, so do you want to replace the other blocks with the newly named block they will be permanently erased though. They are the same looking quickly at dwg ?
Message 8 of 15
Sea-Haven
Trying this as a start but  replaced block and it moved so not sure need to check the insert point in your dwg. Obviously would put in a loop of block names.
(setq ss (ssget "X" (list (cons 0 "insert")(cons 2 "345280*"))))
(repeat (setq x (sslength ss))
(setq obj (vlax-ename->vla-object (ssname ss (setq x (1- x)))))
(vla-put-name obj "345280")
Message 9 of 15
Sea-Haven
Solved the blocks are not the same starting with 345280 if you look at the  blocks the insertion point is different in  the blocks you may need to make the blocks 2 names deep 345280--8536......
Even worse some blocks with same starting sequence are mirrored.
Look at attached images. One block name has like 6 blocks all different.
Message 10 of 15
Moshe-A
@tomwijnholt  hi,
Lets assumes the following blocks has the same geometry - ok?!
345280
before i correct the lisp here is a challenge for you, explore the blocks and tell me:
Does all these blocks has the same insertion point, XYZ scale factor and rotation angle?
cause if they don't? can you imaging the result?
Moshe
Message 11 of 15
Kent1Cooper
@tomwijnholt wrote:
.... I have multiple blocks named:
Would it be acceptable to have the results named something like 345280_1, 345280_2, 345280_3, etc.?  Or maybe 345280A, 345280B, 345280C, etc.?
Kent Cooper, AIA
Message 12 of 15
tomwijnholt
Moshe-A,
thanks for the reply.
You're right, I'm aware of the fact that the blocks have a similar name and geometry.
But this is not always the case for insertion point and rotation angle. And I can imagine how messy it's going to be after running the lisp.
However, the situation is that I have a separate AutoCad file with all the individual blocks redrawn in a simplified version. And that I have an AutoCad file with all the blocks combined in window profiles. (see attachments)
The idea is that I run the lisp in the DWG with the combined profiles, so all the blocks have the same name as in the other DWG. Than I will copy the profiles in the other DWG so the blocks will change automatically.
I still believe it's quicker to run the lisp and adjust the locations instead of placing all the individual blocks in the right location.
I hope it all makes sense to you, if it's not clear, let me know.
Message 13 of 15
tomwijnholt
Kent Cooper,
Thanks or the reply, but this is not acceptable.
Because of the reason subscribed in my reply to moshe-A
Message 14 of 15
Moshe-A
OK, try this
	        iSuccsess iFailure ss exeBName newBName p elist)
  (cond
    nil
   ( t
  ); cond
 ); conclusion
  (progn
    (if (and
     (progn
     ); progn
    ); if
   ); foreach
    (setq elist (entget ename))
    (setq extBName (cdr (assoc '2 elist))) ; existing name
    (if (and
     (entmod (subst (cons '2 newBName) (assoc '2 elist) elist))
    ); if
   ); foreach
  ); progn
 ); if
 (princ)
); mrb
Message 15 of 15
tomwijnholt
Tanks a lot.
Exactly what I needed.
