Block Name Tag Replace
It's me again.. Everyone from my last "Projekt" will roll his eyes exactly at this point. 😄
Easy as that. I guess.. ?
If the block only got one Attribute change the name of the Attribute to "C".
Don't want to insert old Tag name or Block name - Just the condition - If only one Attribute - Change Name to "C".
The more i work with LISP the more i think im retardet.. Thanks for the Help before hand.
Last Posts about the topic, atleast close the Topic.
Change Attribute Tags by their Position instead of the Name
Blockreplace - keeping Value with same Attribute tags
Change every Attribute Tag Gloabally
As always Inb4 some asks - cant post a example .dwg, sorry about that.
Sea-Haven
try this
(setq  doc (vla-get-activedocument (vlax-get-acad-object)))
(setq allblocks (vla-get-blocks doc))
(vlax-for block allblocks
   (setq tot 0)
   (setq bname (vla-get-name block))
        (vlax-for ent block
                (if (=  (vla-get-objectname ent) "AcDbAttributeDefinition" )
                     (setq tot (+ tot 1))
    (if (= tot 1)
        (vlax-for ent block
                 (vla-put-tagstring ent "C")
        (command "attsync" "Name" bname)
Works Perfectly Fine! Thank you very much!
