Visual LISP, AutoLISP and General Customization
dialog box
2 REPLIES 2
marlance
481 Views, 2 Replies
dialog box
How can I create a dialog box with this simple code?
(defun c:test ()
(setq |CMDECHO| (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setvar "osmode" 512)
(setq a (getreal"\nEnter A: "))
(setq b (getreal"\nEnter B: "))
(setq c (+ a b))
(command"text" "0,0" 2.5 "0" c "")
(princ)
2 REPLIES 2
smaher12
in reply to: marlance
The lsp.....
(defun c:test ()
  (setq oldecho (getvar 'cmdecho))
  (setvar 'osmode 512)
  (initiate)
  (setq c (+ a b))
  (command "_.text" "0,0" 2.5 0 (rtos c 2 0))
 (princ)
(defun initiate ()
  (setq dcl_id (load_dialog "test.dcl"))
  (if (not (new_dialog "test" dcl_id))
    (exit)
  (action_tile "aa" "(setq a (distof $value))")
  (action_tile "bb" "(setq b (distof $value))")
  (action_tile "accept" "(done_dialog)")
  (action_tile "cancel" "(exit)")
   (start_dialog)
    (unload_dialog dcl_id)
     (princ)
The dialog box....
test : dialog {
   label = "Sandbox" ;
spacer ;
:row {
 : boxed_column {
  label = "Specifications ";
 : edit_box {
   label = "A:";
   key = "aa";
   edit_width = 5;
   allow_accept = false;
 : edit_box {
   label = "B:";
   key = "bb";
   edit_width = 5;
 } // end boxed_radio_column
} // end row
  ok_cancel;
hmsilva
Hi rulep21.
Just as a different approach, rebuilt from an old demo, that tests the entered value if valid one, prior to submitting to the addition.
I did't include in the code the getvar/setvar and I entmake the Text.
Hope that helps!
Henrique
Forma Design Contest
AutoCAD Beta
