Dialog box called with DCL program not closing
Message 1 of 8
In continuation to my program I wanted to conclude the program with Dialog fox displaying program successfully run .
I have used following DCL to show the same on screen >>
FLNG_FINAL : dialog {
     label = "Congrats !!!!";
     spacer;
     spacer;
      : text {
        value = "FLNG Program Successfully run !!";
        alignment = centered;
        width = 30;
     spacer;
     spacer;
     : button {
     key = "cancel";
     label = " ok ";
     is_default = true;
     is_cancel = true;
Unfortunately I m unable to close this below dialog box even after clicking OK button or Escape or anything ..and finally I have to End Task.
I tried various options and finally posting here to help. Please help, would be greatful.
regards,
TOMES
Replies (7)
Message 2 of 8
hmsilva
Hi TOMES,
do you need to use an external '*.dcl' file in your code?
Why not an
(alert (strcat "Congrats !!!\n\n" "FLNG Program Successfully run !!!"))
or
(ACET-UI-MESSAGE
    "Congrats !!!"
    (+ Acet:OK Acet:ICONINFORMATION)
or
(ACET-UI-MESSAGE
    "Congrats !!!"
    (+ Acet:OK 0)
Hope this helps,
Henrique
Message 3 of 8
paullimapa
Please include your lisp code so we can all look at your callback functions.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 4 of 8
scot-65
Somewhere in between the call of "(new dialog..." and
"(start_dialog)" in your lisp file add this line:
(action_tile "cancel" "(done_dialog)")
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 5 of 8
Hi Henrique,
Once again thanks for being my saviour.
Your all three options work absoutley fine. Thanks a lot !!!
regards,
TOMES
Message 6 of 8
Thanks pli, already got the soultion, thanks for your time.
- TOMES
Message 7 of 8
Thanks scot-65, already got the soultion, thanks for your time.
- TOMES
Message 8 of 8
hmsilva
@Anonymous wrote:
Hi Henrique,
regards,
TOMES
You're welcome, TOMES
Glad I could help
Henrique
