get x,y,z coordinate from multiple points
jyan2000
Message 1 of 12
jyan2000
Is it possible to get x,y,z coordinate from the selected point/s as shown in attached image.
Best regards,
Victor.
Replies (11)
Message 2 of 12
hmsilva
Best regards,
Victor.
Hi Victor,
quick and dirty...
(defun c:demo (/ ent i pt ss txtx txty txtz)
    (if (setq ss (ssget '((0 . "POINT"))))
        (repeat (setq i (sslength ss))
            (setq ent  (entget (ssname ss (setq i (1- i))))
                  pt   (cdr (assoc 10 ent))
                  txtx (strcat "X=" (rtos (car pt) 2 2) "\\P")
                  txty (strcat "Y=" (rtos (cadr pt) 2 2) "\\P")
                  txtz (strcat "Z=" (rtos (caddr pt) 2 2))
            (entmake (list
                         '(0 . "MTEXT")
                         '(100 . "AcDbEntity")
                         '(100 . "AcDbMText")
                         (cons 10 (list (car pt) (cadr pt)))
                         (cons 1 (strcat txtx txty txtz))
    (princ)
Hope this helps,
Henrique
Message 3 of 12
dbroad
@hmsilva has given a good solution if the need is to create an mtext object to document a point's location.
If this is intended as a point labelling device though, you should create a dynamic block with block placeholder fields inside its attributes that document the block's insertion point.  The block would probably be best an annotative one.  Then documenting and placing the block would be automatic.
Architect, Registered NC, VA, SC, & GA.
Message 4 of 12
jyan2000
Its perfect.. that what I was looking for. Thanks a lot Henrique..
best regards
Victor
Message 5 of 12
hmsilva
best regards
Victor
You're welcome, Victor
Glad I could help
Henrique
Message 6 of 12
Kent1Cooper
Here's a question:
That assembles an XY-only insertion point for the Mtext, so all the labels will be at Z=0, and associates it with a 10 for use as the insertion point in the entity data list.  But I assume, since the Z coordinate is part of the label, that the Points can be at different Z coordinates.  Should the Mtext labels be located at each Point's location in all three coordinates?  If so, there's no need to take the location and re-associate it with a 10, but you can use it already associated that way directly from the Point's entity data list.  [You can also eliminate a few variables that are used only once, by just constructing the text string right in the (entmake) list.]
(defun c:demo (/ ent i pt ss)
    (repeat (setq i (sslength ss)); then
      (setq
      (entmake
        (list
          '(0 . "MTEXT")
          (assoc 10 ent)
          (cons 1
            (strcat
            ); strcat
          ); cons
        ); list
      ); entmake
    ); repeat
  ); if
  (princ)
); defun
By the way, if an XY-only insertion point is wanted, this:
can be simplified, to just this:
  (list 10 (car pt) (cadr pt))
Kent Cooper, AIA
Message 7 of 12
hmsilva
@Kent1Cooper wrote:
Here's a question:
That assembles an XY-only insertion point for the Mtext, so all the labels will be at Z=0, ...
I did put all Mtext at z=0, because our standards (we don't use 3d text), if OP need the MText with the same elevation as Point, it could be modified.
Yes, your comments regarding the creation of three variables are correct, but, I think that creating those three variables, makes the code easier to read and understand, to the OP...
Thank you
Henrique
Message 8 of 12
jyan2000
Thank you a lot Kent Cooper. Your code looks perfect too. it looks like in the image.
All my best wishes.
Regards.
Victor
Message 9 of 12
jyan2000
dear Kent Cooper,
I really Loved this code. But, what should I do if I want Z= value  to be ( + / - ) plus or minus 100  but data will shown as " Z: 145.00 - 100 = 45.00" ?
Regards
Victor
Message 10 of 12
Kent1Cooper
@jyan2000 wrote:
... what should I do if I want Z= value  to be ( + / - ) plus or minus 100  but data will shown as " Z: 145.00 - 100 = 45.00" ?
I'm not quite sure I understand exactly what you're asking [another sample image would be helpful], but you can construct such a string.  To get what you show at the end, but using whatever the actual Z value is in place of the example 145.00, replace this line:
with this:
"Z: " (rtos (caddr pt) 2 2) " - 100 = " (rtos (- (caddr pt) 100) 2 2)
You could also have the routine ask for a value [positive or negative] in place of the 100, earlier:
(setq Zoffs (getdist "\nZ-coordinate plus/minus value: "))
and build the string to show that value and account for whether it's positive or negative [untested]:
"Z: " (rtos (caddr pt) 2 2) " " (if (minusp Zoffs) "-" "+") " " (rtos Zoffs 2 2) " = " (rtos (- (caddr pt) Zoffs) 2 2)
You could use (getreal) instead of (getdist) for the Zoffs value; (getdist) allows on-screen distance pick if desired, but for a negative value the User wouldn't be able to do that, but would need to type it in.
Kent Cooper, AIA
Message 11 of 12
jyan2000
Applause once again Kent Cooper,
That was complete satisfaction. what I meant with plus or minus ( + / - ) was,
or
"Z: " (rtos (caddr pt) 2 2) " + 100 = " (rtos (+ (caddr pt) 100) 2 2)
So I could able to add or extract desired digit to Z value.
Thanks a lot.
Best Regards.
Victor
Message 12 of 12
Kent1Cooper
I'm glad you like it, but I realize I made one mistake.  The blue line above should be:
"Z: " (rtos (caddr pt) 2 2) " " (if (minusp Zoffs) "-" "+") " " (rtos Zoffs 2 2) " = " (rtos (+ (caddr pt) Zoffs) 2 2)
because the User's input of a positive or negative value will determine whether it increases or decreases the Point's Z coordinate's value.
Kent Cooper, AIA
