Convert All vports in All Layouts from Polygonal to Rectangular
danglar
danglar
I wrote a simple lisp to convert a single vport from poligonal form to rectangular:
(defun c:vpr ()
 (setvar "cmdecho" 0)
 (setq switch (command "_.pspace"))
 (setq selections (entsel "Select Polygonal VPort to convert to Rectangular: "))
 (command "vpclip" selections "d" )
It works nice, but I need to convert a huge bunch of viewports at once...
Can you improve my programm in order to Convert All vports in All Layouts at once?
Any help will be very appreciated
phanaem
The clipped status of a viewport is read only, so you cannot change it via ActiveX.
You cannot entmod a viewport, so you must relay on command.
(defun c:test (/ *error* acdoc cmd ss i e)
  (setq acdoc (vla-get-activedocument (vlax-get-acad-object))
        cmd (getvar 'cmdecho))
  (vla-startundomark acdoc)
  (setvar 'cmdecho 0)
  (defun *error* (msg)
    (and
      msg
      (not (wcmatch (strcase msg) "*CANCEL*,*QUIT*,*EXIT*"))
      (princ (strcat "\nError: " msg))
    (setvar 'cmdecho cmd)
    (vla-endundomark acdoc)
    (princ)
  (foreach lo (layoutlist)
    (setvar 'ctab lo)
    (vla-put-mspace acdoc :vlax-false)
    (if
      (setq ss (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 lo) '(-4 . ">") '(68 . 1))))
      (repeat (setq i (sslength ss))
        (setq e (ssname ss (setq i (1- i))))
        (if
          (= (logand 65536 (cdr (assoc 90 (entget e)))) 65536); or (assoc 340 (entget e)) ??? -> clipped viewport
          (command "_clip" e "_d")
  (*error* nil)
  (princ)
danglar
Works Perfect! Thank You!
