(defun C:DGN2DWG_batch_rev (/ fil tx1 tx2 tx3 tx4 tx5)
(setq tx1 "R:\Scanned_Files\Scanned_Files_TUL\DWG's\RW 18R-36L Safety Area 2013 Asbids\RW 18R-36L Safety Area 2013 Asbids\As-Bid CAD files\DGN-LIST.txt"
tx2 "R:\Scanned_Files\Scanned_Files_TUL\DWG's\RW 18R-36L Safety Area 2013 Asbids\RW 18R-36L Safety Area 2013 Asbids\As-Bid CAD files\"
tx3 "R:\Scanned_Files\Scanned_Files_TUL\DWG's\RW 18R-36L Safety Area 2013 Asbids\RW 18R-36L Safety Area 2013 Asbids\As-Bid CAD files\DWG\"
tx4 "Default"
(setvar "DGNIMPORTMODE" 1)
(setq fil (open tx1 "r")
tx5 (read-line fil)) ; repeats program until all lines from the list with *.dgn drawing names are read.
(while tx5 ; strips an extension with length of 3 characters from the drawing name, if present.
(if (wcmatch tx5 "*`.???")
(setq tx5 (substr tx5 1 (- (strlen tx5) 4)))
(command "_UNDO" "_MARK"
"_DGNIMPORT" (strcat tx2 tx5) tx4 "" ""
"_ZOOM" "_E"
"_DELAY" 500
"_SAVEAS" "2000(LT2000)" (strcat tx3 tx5)
(command "_ERASE" "ALL" "") ;erases everything on the page after the save
(command "_.purge" "_all" "" "_no") ;purges everything so you don't carry it over to the next drawing
(command "_.purge" "_regapp" "" "_no")
(command "_QNEW") ;opens a new drawing
(setq tx5 (read-line fil))
(close fil)
(command "_QUIT" "_Y")
(princ)
)Set correct paths, and don't use ' in directory name (dwg's). Try to run and report result.
Miljenko Hatlak
