DGN to DWG LISP Program Not Working
jalwgis
Message 1 of 8
jalwgis
I'm getting error when running a LISP program to batch convert a number of DGN files to DWG.
The first error I got was when I loaded the lsp file. The second error I got was when I tried to execute the lsp file.
I've attached the error files and lsp file.
Any help is appreciated.
Accepted solutions (4)
Replies (7)
Message 2 of 8
devitg
Please upload a sample.dgn file
Message 3 of 8
devitg
You lost 2 double quotes  search "
(setq tx1 "R:\Scanned_Files\Scanned_Files_TUL\DWG's\RW 18R-36L Safety Area 2013 Asbids\RW 18R-36L Safety Area 2013 Asbids\As-Bid CAD files\DGN-LIST.txt" ;; example variable: file holding a list of *.dgn's names to be imported.
tx2 "R:\Scanned_Files\Scanned_Files_TUL\DWG's\RW 18R-36L Safety Area 2013 Asbids\RW 18R-36L Safety Area 2013 Asbids\As-Bid CAD files\"" ;; example variable: input folder.
tx3 "R:\Scanned_Files\Scanned_Files_TUL\DWG's\RW 18R-36L Safety Area 2013 Asbids\RW 18R-36L Safety Area 2013 Asbids\As-Bid CAD files\DWG\"" ;; example variable: output folder.
tx4 "Default" ;; example variable: drawing model name
Message 4 of 8
hak_vz
(defun C:DGN2DWG_batch_rev (/ fil tx1 tx2 tx3 tx4 tx5)
       tx4 "Default"
 (setvar "DGNIMPORTMODE" 1)
 (setq fil (open tx1 "r")
       tx5 (read-line fil))         ; repeats program until all lines from the list with *.dgn drawing names are read.
 (while tx5                         ; strips an extension with length of 3 characters from the drawing name, if present.
   (if (wcmatch tx5 "*`.???")
     (setq tx5 (substr tx5 1 (- (strlen tx5) 4)))
   (command "_UNDO" "_MARK"
            "_DGNIMPORT" (strcat tx2 tx5) tx4 "" ""
            "_ZOOM" "_E"
            "_DELAY" 500
            "_SAVEAS" "2000(LT2000)" (strcat tx3 tx5)
   (command "_ERASE" "ALL" "")                ;erases everything on the page after the save
   (command "_.purge" "_all" "" "_no")        ;purges everything so you don't carry it over to the next drawing
   (command "_.purge" "_regapp" "" "_no")
   (command "_QNEW")                          ;opens a new drawing
   (setq tx5 (read-line fil))
  (close fil)
 (command "_QUIT" "_Y")
 (princ)
Set correct paths, and don't use ' in directory name (dwg's). Try to run and report result.
Miljenko Hatlak
Message 5 of 8
devitg
Check if it work
Message 6 of 8
jalwgis
Thank you for your help. I will test and let you know if it works.
Message 7 of 8
jalwgis
Why the two double quotes on variables TX2 & TX3 and not TX1?
Message 8 of 8
jalwgis
I got the script to work. Gave me the same error message after adding the double quotes. Moving the drawings to another directory that didn't have the ' in DWG'S worked. Here is the script after making the changes:
(defun C:DGN2DWG_batch_rev-modified (/ fil tx1 tx2 tx3 tx4 tx5)
(SETQ TX1 "U:\\DWGS\\RW 18R-36L Safety Area 2013 Asbids\\DGN-LIST.txt"
;; Added another forward slash- 12-9-2019
TX2 "U:\\DWGS\\RW 18R-36L Safety Area 2013 Asbids\\"
;; Added another forward slash and deleted double quote at the end - 12-9-2019
TX3 "U:\\DWGS\\RW 18R-36L Safety Area 2013 Asbids\\DWG\\"
TX4 "Default"
Thanks for your help!
