Carlos, I've made new input on the link I provided at theswamp... If you are unable to access it, I'll post here my latest version of edgenet routine...
(defun c:edgenet-new ( / *error* gridcoeff *adoc* e1 e2 e3 e4 m n de1 de2 de3 de4 lst mm nn p1 p2 p3 p4 ll lr ur ul kll klr kur kul il plst pplst pmsh ex )
(vl-load-com)
(defun *error* ( m )
(vla-endundomark *adoc*)
(if m
(prompt m)
(redraw e1 4)
(redraw e2 4)
(redraw e3 4)
(redraw e4 4)
(princ)
(defun gridcoeff ( m n il ex / mp mm nn p ll lr ul ur lst )
(setq mp (list (/ m 2) (/ n 2)) mm 0)
(repeat m
(setq mm (1+ mm) nn 0)
(repeat n
(setq nn (1+ nn))
(setq p (list mm nn))
(setq ll (list (+ (* (if (<= (1- nn) (cadr mp)) 1.0 -1.0) (expt (/ (float (abs (- (cadr mp) (1- nn)))) (float (cadr mp))) 2) (- (car (nth 1 il)) (cadr (nth 4 il)))) (cadr (nth 4 il)))
(+ (* (if (<= (1- mm) (car mp)) -1.0 1.0) (expt (/ (float (abs (- (car mp) (1- mm)))) (float (car mp))) 2) (- (cadr (nth 5 il)) (caddr (nth 4 il)))) (caddr (nth 4 il)))
(+ (* (if (<= (1- nn) (cadr mp)) -1.0 1.0) (expt (/ (float (abs (- (cadr mp) (1- nn)))) (float (cadr mp))) 2) (- (caddr (nth 7 il)) (cadddr (nth 4 il)))) (cadddr (nth 4 il)))
(+ (* (if (<= (1- mm) (car mp)) 1.0 -1.0) (expt (/ (float (abs (- (car mp) (1- mm)))) (float (car mp))) 2) (- (cadddr (nth 3 il)) (car (nth 4 il)))) (car (nth 4 il)))
(setq lr (list (+ (* (if (<= (1- nn) (cadr mp)) 1.0 -1.0) (expt (/ (float (abs (- (cadr mp) (1- nn)))) (float (cadr mp))) 2) (- (car (nth 1 il)) (cadr (nth 4 il)))) (cadr (nth 4 il)))
(+ (* (if (<= mm (car mp)) -1.0 1.0) (expt (/ (float (abs (- (car mp) mm))) (float (car mp))) 2) (- (cadr (nth 5 il)) (caddr (nth 4 il)))) (caddr (nth 4 il)))
(+ (* (if (<= mm (car mp)) 1.0 -1.0) (expt (/ (float (abs (- (car mp) mm))) (float (car mp))) 2) (- (cadddr (nth 3 il)) (car (nth 4 il)))) (car (nth 4 il)))
(setq ul (list (+ (* (if (<= nn (cadr mp)) 1.0 -1.0) (expt (/ (float (abs (- (cadr mp) nn))) (float (cadr mp))) 2) (- (car (nth 1 il)) (cadr (nth 4 il)))) (cadr (nth 4 il)))
(+ (* (if (<= nn (cadr mp)) -1.0 1.0) (expt (/ (float (abs (- (cadr mp) nn))) (float (cadr mp))) 2) (- (caddr (nth 7 il)) (cadddr (nth 4 il)))) (cadddr (nth 4 il)))
(setq ur (list (+ (* (if (<= nn (cadr mp)) 1.0 -1.0) (expt (/ (float (abs (- (cadr mp) nn))) (float (cadr mp))) 2) (- (car (nth 1 il)) (cadr (nth 4 il)))) (cadr (nth 4 il)))
(setq lst (cons (list p ll lr ul ur) lst))
(setq lst (mapcar '(lambda ( x ) (cons (car x) (mapcar '(lambda ( y ) (mapcar '(lambda ( z ) (expt z ex)) y)) (cdr x)))) lst))
(setq mm 0)
(repeat m
(repeat n
(setq nn (1+ nn))
(if (= mm 1)
(setq lst (subst (list p (list 0.0 0.0 0.0 1.0) (nth 2 (assoc p lst)) (list 0.0 0.0 0.0 1.0) (nth 4 (assoc p lst))) (assoc p lst) lst))
(if (= nn 1)
(setq lst (subst (list p (list 1.0 0.0 0.0 0.0) (list 1.0 0.0 0.0 0.0) (nth 3 (assoc p lst)) (nth 4 (assoc p lst))) (assoc p lst) lst))
(if (= mm m)
(setq lst (subst (list p (nth 1 (assoc p lst)) (list 0.0 1.0 0.0 0.0) (nth 3 (assoc p lst)) (list 0.0 1.0 0.0 0.0)) (assoc p lst) lst))
(if (= nn n)
(setq lst (subst (list p (nth 1 (assoc p lst)) (nth 2 (assoc p lst)) (list 0.0 0.0 1.0 0.0) (list 0.0 0.0 1.0 0.0)) (assoc p lst) lst))
(if (and (= mm 1) (= nn 1))
(setq lst (subst (list p (list 1.0 0.0 0.0 1.0) (nth 2 (assoc p lst)) (nth 3 (assoc p lst)) (nth 4 (assoc p lst))) (assoc p lst) lst))
(if (and (= mm 1) (= nn n))
(setq lst (subst (list p (nth 1 (assoc p lst)) (nth 2 (assoc p lst)) (list 0.0 0.0 1.0 1.0) (nth 4 (assoc p lst))) (assoc p lst) lst))
(if (and (= mm m) (= nn 1))
(setq lst (subst (list p (nth 1 (assoc p lst)) (list 1.0 1.0 0.0 0.0) (nth 3 (assoc p lst)) (nth 4 (assoc p lst))) (assoc p lst) lst))
(if (and (= mm m) (= nn n))
(setq lst (subst (list p (nth 1 (assoc p lst)) (nth 2 (assoc p lst)) (nth 3 (assoc p lst)) (list 0.0 1.0 1.0 0.0)) (assoc p lst) lst))
(reverse lst)
(vla-startundomark (setq *adoc* (vla-get-activedocument (vlax-get-acad-object))))
(prompt "\nPick OPEN edge drawn in CCW direction - 1st edge of NET...")
(setq e1 (ssget "_+.:E:S" '((0 . "*POLYLINE,ARC,SPLINE,ELLIPSE,LINE"))))
(while (or (not e1) (vlax-curve-isclosed (ssname e1 0)))
(prompt "\nMissed or picked curve isn't open... Please pick 1st edge again...")
(if e1
(progn
(setq e1 (ssname e1 0))
(redraw e1 3)
(prompt "\nPick OPEN edge drawn in CCW direction - 2nd edge of NET...")
(setq e2 (ssget "_+.:E:S" '((0 . "*POLYLINE,ARC,SPLINE,ELLIPSE,LINE"))))
(while (or (not e2) (vlax-curve-isclosed (ssname e2 0)))
(prompt "\nMissed or picked curve isn't open... Please pick 2nd edge again...")
(if e2
(progn
(setq e2 (ssname e2 0))
(redraw e2 3)
(prompt "\nPick OPEN edge drawn in CCW direction - 3rd edge of NET...")
(setq e3 (ssget "_+.:E:S" '((0 . "*POLYLINE,ARC,SPLINE,ELLIPSE,LINE"))))
(while (or (not e3) (vlax-curve-isclosed (ssname e3 0)))
(prompt "\nMissed or picked curve isn't open... Please pick 3rd edge again...")
(if e3
(progn
(setq e3 (ssname e3 0))
(redraw e3 3)
(prompt "\nPick OPEN edge drawn in CCW direction - 4th edge of NET...")
(setq e4 (ssget "_+.:E:S" '((0 . "*POLYLINE,ARC,SPLINE,ELLIPSE,LINE"))))
(while (or (not e4) (vlax-curve-isclosed (ssname e4 0)))
(prompt "\nMissed or picked curve isn't open... Please pick 4th edge again...")
(if e4
(progn
(setq e4 (ssname e4 0))
(redraw e4 3)
(initget 7)
(setq m (getint "\nSpecify divisions in M direction : "))
(while (= (rem m 2) 1)
(prompt "\nM number must be even number - not odd... Please input M divisions again...")
(initget 7)
(initget 7)
(setq n (getint "\nSpecify divisions in N direction : "))
(while (= (rem n 2) 1)
(prompt "\nN number must be even number - not odd... Please input N divisions again...")
(initget 7)
(initget 6)
(setq ex (getreal "\nSpecify tension exponent <4.0> : "))
(if (null ex)
(setq ex 4.0)
(setq il '((1.0 0.0 0.0 1.0) (1.0 0.0 0.0 0.0) (1.0 1.0 0.0 0.0) (0.0 0.0 0.0 1.0) (0.5 0.5 0.5 0.5) (0.0 1.0 0.0 0.0) (0.0 0.0 1.0 1.0) (0.0 0.0 1.0 0.0) (0.0 1.0 1.0 0.0)))
(setq de1 (/ (vlax-curve-getdistatparam e1 (vlax-curve-getendparam e1)) m))
(setq de2 (/ (vlax-curve-getdistatparam e2 (vlax-curve-getendparam e2)) n))
(setq de3 (/ (vlax-curve-getdistatparam e3 (vlax-curve-getendparam e3)) m))
(setq de4 (/ (vlax-curve-getdistatparam e4 (vlax-curve-getendparam e4)) n))
(setq lst (gridcoeff m n il ex))
(setq mm 0)
(repeat m
(setq nn 0 mm (1+ mm))
(repeat n
(setq nn (1+ nn))
(setq kll (nth 1 (assoc p lst)) klr (nth 2 (assoc p lst)) kul (nth 3 (assoc p lst)) kur (nth 4 (assoc p lst)))
(setq p1 (vlax-curve-getpointatdist e1 (* mm de1)))
(setq p2 (vlax-curve-getpointatdist e2 (* nn de2)))
(setq p3 (vlax-curve-getpointatdist e3 (* (- m mm) de3)))
(setq p4 (vlax-curve-getpointatdist e4 (* (- n nn) de4)))
(setq ur (mapcar '(lambda ( a b c d ) (/ (+ (* a (nth 0 kur)) (* b (nth 1 kur)) (* c (nth 2 kur)) (* d (nth 3 kur))) (+ (nth 0 kur) (nth 1 kur) (nth 2 kur) (nth 3 kur)))) p1 p2 p3 p4))
(setq p1 (vlax-curve-getpointatdist e1 (* (1- mm) de1)))
(setq p2 (vlax-curve-getpointatdist e2 (* (1- nn) de2)))
(setq p3 (vlax-curve-getpointatdist e3 (* (1+ (- m mm)) de3)))
(setq p4 (vlax-curve-getpointatdist e4 (* (1+ (- n nn)) de4)))
(setq ll (mapcar '(lambda ( a b c d ) (/ (+ (* a (nth 0 kll)) (* b (nth 1 kll)) (* c (nth 2 kll)) (* d (nth 3 kll))) (+ (nth 0 kll) (nth 1 kll) (nth 2 kll) (nth 3 kll)))) p1 p2 p3 p4))
(setq lr (mapcar '(lambda ( a b c d ) (/ (+ (* a (nth 0 klr)) (* b (nth 1 klr)) (* c (nth 2 klr)) (* d (nth 3 klr))) (+ (nth 0 klr) (nth 1 klr) (nth 2 klr) (nth 3 klr)))) p1 p2 p3 p4))
(setq ul (mapcar '(lambda ( a b c d ) (/ (+ (* a (nth 0 kul)) (* b (nth 1 kul)) (* c (nth 2 kul)) (* d (nth 3 kul))) (+ (nth 0 kul) (nth 1 kul) (nth 2 kul) (nth 3 kul)))) p1 p2 p3 p4))
;;; (entmake (list '(0 . "3DFACE") (cons 10 ll) (cons 11 lr) (cons 12 ur) (cons 13 ul)))
(setq plst (cons ll plst))
(if (= nn n)
(setq plst (cons ul plst))
(if (= mm m)
(setq pplst (cons lr pplst))
(setq pplst (cons ur pplst))
(foreach p (reverse pplst)
(setq plst (cons p plst))
(setq pmsh (entmakex (list '(0 . "POLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolygonMesh") '(66 . 1) '(10 0.0 0.0 0.0) '(70 . 16) '(40 . 0.0) '(41 . 0.0) '(210 0.0 0.0 1.0) (cons 71 (1+ m)) (cons 72 (1+ n)) '(73 . 0) '(74 . 0) '(75 . 0))))
(foreach p (reverse plst)
(entmake (list '(0 . "VERTEX") '(100 . "AcDbEntity") '(100 . "AcDbVertex") '(100 . "AcDbPolygonMeshVertex") (cons 10 p) '(40 . 0.0) '(41 . 0.0) '(42 . 0.0) '(70 . 64) '(50 . 0.0) '(71 . 0) '(72 . 0) '(73 . 0) '(74 . 0)))
(entmake (list '(0 . "SEQEND") '(100 . "AcDbEntity") (cons -2 pmsh)))
(*error* nil)
I hope you'll find it useful... If you are satisfied with solution you can mark it, but I've already explained, you already have built-in commands like EDGESURF, REVSURF, RULESURF and TABSURF and they all work in relation of changeable system variables SURFTAB1 for M density and SURFTAB2 for N density... BTW. I also don't have MPanel plugin for AutoCAD, so we are even at that issue...
Regards, all the best M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
