Visual LISP, AutoLISP and General Customization
Delete all solid hatches
33 REPLIES 33
Message 1 of 34
kameron1967
30144 Views, 33 Replies
Hi guys,
I would like to be able to go into a drawing and delete all solid hatches from all layers.  Is this possible?  Thank you kindly. 🙂
Kameron
33 REPLIES 33
Message 21 of 34
in reply to: Kent1Cooper
Hi again, all objects is in same layer, but with different colours- in this case I want to delete all hatches within multiple blocks that are colour overrided White.
Thanks for your effort
Message 22 of 34
Kent1Cooper
Do you also have other Insertions of the same Block(s), without  the white color override [whether with no color override or with a different color] that contain the same Hatch objects?  If that's the case, you can't remove the Hatch from the Block definitions.  You may need to Explode  all those Blocks and then delete the Hatches.
Kent Cooper, AIA
Message 23 of 34
in reply to: kameron1967
What do you enter in the Command Prompt to execute this .LISP? I loaded it, but don't know how to execute it?
Corey Barge
Message 24 of 34
rkmcswain
@Anonymous - if you are talking about the lisp code in post #2, then it's "delsolhat"
R.K. McSwain     | CADpanacea | on twitter
Message 25 of 34
Hi
No, all solid white hatches, in different shape and size, within different blocks shall be cleaned out. Boundaries should stay.
Message 26 of 34
Kent1Cooper
@Anonymous wrote:
.... all solid white hatches, in different shape and size, within different blocks shall be cleaned out. Boundaries should stay.
Try this addition to the code in Post 2:
(if (and (= "AcDbHatch" (vla-get-objectname o)) (= "SOLID" (strcase (vla-get-patternname o))) (= 7 (vla-get-Color o))
(vlax-write-enabled-p o) ) (vla-delete o) )
Kent Cooper, AIA
Message 27 of 34
Hi Again,
I tried the code like this:
(defun c:delsolwhat ( / d )
(vlax-for b (vla-get-blocks (setq d (vla-get-activedocument (vlax-get-acad-object))))
(if (= :vlax-false (vla-get-isxref b))
(vlax-for o b
(vla-regen d acallviewports)
(princ)
(vl-load-com) (princ)
And it is partly working, when executing It seems that the command is performed, but no changes appear. If I manually type and run BURST afterwards, all the solid white hatches disappear, and it seems that the blocks is intact. I'm not sure if burst explodes only one level that doesn't have any effects.
Message 28 of 34
DarrenLowe5325
in reply to: Lee_Mac
The lisp routine does not work in AutoCAD 2018.
@Lee_Mac wrote:
The following will delete all solid hatches from all layouts and from within blocks & nested blocks (nested to any level):
(defun c:delsolhat ( / d )
            (vlax-for o b
                    (vla-delete o)
    (princ)
Message 29 of 34
rkmcswain
in reply to: DarrenLowe5325
It works fine in 2018 and 2019 for me.
@Lee_Mac
Message 30 of 34
DarrenLowe5325
in reply to: rkmcswain
I reinstalled AutoCAD 2018 and now it works.
That was much easier than going into the registry.
Thank you. Awesome LISP routine. Architects use Revit and they always export CAD files with solid hatching. I love deleting all of the solid.
Message 31 of 34
Yes, LeeMac is a wiz. He's got so many useful routines. This is definitely one of them! 🙂
Message 32 of 34
ajmalnattika
dear lee mac,
how can i do this one using selection
Message 33 of 34
rosst5ZL4H
Anything from 2024. Can't get rid of all "Fill" on a supplied drawing. Can't turn fill off as my own blocks use a fill. Turn off Fill ad then Xref the fill is back showing again.
Message 34 of 34
rosst5ZL4H
No it does not work at least not in Version 2023
Forma Design Contest
AutoCAD Beta
