DCL radio button insert block
god17169
god17169
hello guys, i'am a novice on this, i have read about dcl and i was able to create one
title : dialog {
label = "Drawing Title" ;
:boxed_radio_column {
label = "Type" ;
: radio_button {
key = "rb1" ;
label = "&Title" ;
value = "1" ;
: radio_button {
key = "rb2" ;
label = "&Detail" ;
: radio_button {
key = "rb3" ;
label = "&Section" ;
:edit_box {
label="Drawing Name: ";
key = "name";
edit_limit = 30;
edit_width = 30;
:edit_box {
label="Drawing Scale: ";
key = "scale";
edit_limit = 30;
edit_width = 30;
ok_cancel ;
: paragraph {
: text_part {
label = "Designed and Created";
: text_part {
label = "by AkosiChris";
now i want an lisp file that when i click radio button "Title" it would insert a block that will use the data on edit_box "Drawing name" and "drawing scale". Same should happen if i click "Detail" or Section"
I;am having a hard time on this, so far i can only load the dcl but i dont know the code to insert the block and call the data in edit_box to be in the attribute of the inserted block.
(defun C:title ()
(setq p1 (getpoint "\nPick Insertion point:"))
(setq radio_option $value)
if(= radio_option "rb1")
(cond
((=radio_option "0") (command "-Insert" "STEPUP.dwg" "_non" pt "" pause))
((=radio_option "1") (command "-Insert" "STEPUP.dwg" "_non" pt "" pause))
(if(= radio_option "rb2")
((=radio_option "0") (command "-Insert" "STEPSLOPE.dwg" "_non" pt "" pause))
((=radio_option "1") (command "-Insert" "STEPSLOPE.dwg" "_non" pt "" pause))
(setq dcl_id (load_dialog "drawingtitle.dcl"))
(if (not (new_dialog "title" dcl_id)
(exit)
(set_tile "A/1" "Enter Number/Letter Here")
(mode_tile "name" 2)
(action_tile "A/1" "(setq A/1 $value)")
(action_tile "rdwg" "(setq rdwg $value)")
(action_tile "rb1" "(setq hole \"title\")")
(action_tile "rb2" "(setq hole \"scale\")")
(action_tile
"cancel"
"(setq ddiag 1) (done_dialog) "
(action_tile
"accept"
"(setq ddiag 2) (done_dialog) "
(start_dialog)
(unload_dialog dcl_id)
(princ)
(princ)
paullimapa
Check out this tutorial and you'll get a better handle on DCL especially with Radio buttons:
http://www.jefferypsanders.com/autolisp_DCL_Part5.html
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
scot-65
This will get quite lengthy so I will give you a start...
(action_tile "accept" "(TITLE_GET)(done_dialog 1)")
Where:
(TITLE_GET) is a subroutine (function) that will gather
all the tiles status and save these values as a LIST. For your
example, there will be 3 of them. I'm taking a "snapshot"
of the dialog's state just before closing.
Let's take advantage of the done_dialog's integer return to start_dialog:
(setq sd (start_dialog))
From there enter into your "Main" program to evaluate:
(if (and sd (> sd 0))...
Subroutine:
(setq USER_TITLE (list
(get_tile "Rad100") ;<-- need to add key to :boxed_radio_column
(get_tile "name") ;<-- these are text case sensitive
(get_tile "scale")
Access this list using (nth 0 USER_TITLE), (nth 1 USER_TITLE), etc.
By assigning boxed_radio_column to a key, the set_tile and get_tile
values will be any of it's children keys in the radio set.
Try it yourself - remove "value" in the DCL and add inside the LSP
file, under the "Set" section: (set_tile "Rad100" "rb1")
I'm in quick reply here, but I do have a text document that is a
beginning LSP template that uses DCL. Search for it in this forum.
Good Luck.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
smaher12
See if this helps any. Note, you have to enter in your block name in the "YOUR_BLOCK_NAME" section.
(defun c:ss ()
 (defun title_dflt ()
   (if (= typ nil) (setq typ "t"))
   (if (= name nil) (setq name "Drawing Name"))
   (if name (set_tile "name" name))
   (if (= scale nil) (setq scale "Scale: 1/8\" = 1'-0\""))
   (if scale (set_tile "scale" scale))
   (if (= typ "t") (set_tile "rb1" "1"))
   (if (= typ "d") (set_tile "rb2" "1"))
   (if (= typ "s") (set_tile "rb3" "1"))
 ); title_dflt
 (title_set)
  (if
    (setq p1 (getpoint "\nSpecify insertion point: "))
      (progn
	(cond
	  ((= typ "t")
	   (command "-insert" "YOUR_BLOCK_NAME" "_none" p1 "" "" "" name scale)
	  ((= typ "d")
	  ((= typ "s")
	); cond
      ); progn
  ); if
 (princ)
); ss
 (defun title_set ()
   (setq dcl_id (load_dialog "ss.dcl"))
    (if (not (new_dialog "ss" dcl_id))
     (exit)
 (title_dflt)
   (action_tile "rb1" "(setq typ \"t\")")
   (action_tile "rb2" "(setq typ \"d\")")
   (action_tile "rb3" "(setq typ \"s\")")
   (action_tile "name" "(setq name $value)")
   (action_tile "scale" "(setq scale $value)")
   (action_tile "accept" "(done_dialog)")
   (action_tile "cancel" "(exit)")
    (start_dialog)
      (princ)
 ); title_set
(princ)
ss : dialog {
	 label = "Drawing Title";
  spacer;
	: boxed_radio_row {
	  label = "Block Type:";
	  : radio_button {
	    label = "&Title";
	    key = "rb1";
	  : radio_button {
	    label = "&Detail";
	    key = "rb2";
	  : radio_button {
	    label = "&Section";
	    key = "rb3";
	} // end boxed_radio_row
  spacer;
	: boxed_column {
	  label = "Drawing:";
	  : edit_box {
	    label = "Name:";
	    key = "name";
	    edit_width = 30;
	    mnemonic = "T";
	    allow_accept = true;
	  : edit_box {
	    label = "Scale:";
	    key = "scale" ;
	    edit_width = 30 ;
	    mnemonic = "T" ;
	    allow_accept = true ;
	} // end boxed_column
  spacer;
  ok_cancel;
} // end dialog
god17169
thanks for this code smasher12, rely worked, except the part that should call the Drawing name and scale, it did not attached to the inserted blocks, i ill try to find a solution for this on my side, but aside from that this code took me closer to what i was trying to achieve.. apprieciate your time and code..
scot-65
From the above code, name and scale are attributes of the block.
(setvar "ATTDIA" 0) before inserting.
Also, if one can select the names from a list instead of entering
in an edit box, then it will be more user friendly and less prone
to errors.
Look into list_box and/or popup_list.
Scot-65
