- Mute
- Permalink
- Report
Hello guys,
The target is to use attribute tag values from blocks to perform calculations. For that i did a routine that select block, create a list( sublist(block_name1 SWL1 MBL1 EWL1) .....). The "button" on the dialog box is supposed to display the values of the selected block in the popup_list. To extract the values inside the sublist, i use assoc to compare the block_name of the sublist an the one from the popup_list.
I have an issue, i am not able to display those values into the dialog box.
I do not have the expertise to target the issue.
You will find attached a .lsp, .dcl and .dwg.
Thank you very much for your help !!!
Link copied
